Previous in Forum: Earthing DC Cable in One End?   Next in Forum: IR Testing Using DAR (Dielectric Absorbtion Ratio) Time Mode
Panel Standardization
07/14/2012 2:37 AM
In India, what should be the "STANDARD" for Electrical Control panels? And what are the conditions to considered, that the panel should be of a particular STANDARD?
Re: PANEL STANDARDISATION
07/14/2012 4:40 AM
A couple considerations based on ISO; any panel longer than 2 ft requires a fan for cooling. Any panel must have 25% of free space.
07/14/2012 1:10 PM
A standard should be one that can be easily recognized by anyone in the same manner that airplane cockpit instrument panels are laid out; all controls located in the same position so they can be found blindfolded. That is standarization. When push buttons are arbitrarily placed on a panel, the wrong button can be pressed when the operator is not familar with that panel. Standarization is obviously needed in manufacturing and it serves to reduce human error.
Mr.Ron from South Ms.
07/14/2012 2:52 PM
If a standard exists for an electrical control panel in India, that standard should be maintained, made available and inspected by the Indian authorities. I expect that power distribution and not control panels have a standard. Since Indian bureaucracy mirrored British bureaucracy, I expect that only licensed individuals with the latest approved copy of a standard can challenge any inspection result.
Good Answers: 42
Re: Panel Standardization
07/20/2012 12:50 AM
There are relevant Indian standards . Buy them and follow strictly. Please refer Indian
Electricity Rules before making any electrical panels as the user will have to comply with it before charging.
IS 375: 1963 ETD 7 Marking and arrangement for switch gears bus-bars,
main connections and auxiliary wiring (revised)
(superseded by IS: 5578 and IS: 11353)
IS 694: 1986 ETD 9 PVC insulated cables for working voltages upto and
including 1100 V (third revision) (Amendment 1)
IS 13779
IS 13947
(Part 1):1993
ETD 7 Low voltage switchgear and controlgear: Part 1
General rules (superseding IS 4237)
IS 13947
(Part 2):1993
ETD 7 Low voltage switchgear and controlgear: Part 2
Circuit breakers [superseding IS 2516(Part 1 &
2/Sec 1): 1985] (Amendment 1)
IS 13947
(Part 3):1993
ETD 7 Low voltage switchgear and controlgear: Part 3
Switches, disconnectors, switch disconnectors
and fuse combination units [superseding IS
4064(Part 1 and 2)]
IS 13947
(Part 4/Sec1)
: 1993
ETD 7 Low voltage switchgear and controlgear: Part 4
Contractors and motor starters, Sec 1
Electromechanical contactors and motor starters
[superseding IS 2959 & IS 8544(All parts)]
(Amendment 1)
IS 13947
(Part 5/Sec1)
: 1993
ETD 7 Low voltage switchgear and controlgear: Part 5
Control circuit devices and switching elements,
Sec 1 Electromechanical control circuit devices
[superseding IS 6875(All Parts)] (Amendment 1
Good Answers: 170
07/29/2012 10:10 AM
IEC 61439
AW (1); electricalexpert65 (1); redfred (1); ronseto (1); V.I.Abraham (1)
