Previous in Forum: LPG Gas Seamless Steel Pipe - Corrosion Factor   Next in Forum: Packing Leaking in NASH Liquid Vacuum Pump Vectra XL
How Does Vacuum Breaker Valve Protect LPT Diaphragm During Sudden Tripping
07/30/2012 12:20 PM
During sudden turbine trip vacuum breaker valve is actuated to protect LPT diaphragm. How does this action protect LPT diaphragm.
Pathfinder Tags: Condenser power plant turbine Vacuum
Re: How Does Vacuum Breaker Valve Protect LPT Diaphragm During Sudden Tripping
07/31/2012 3:22 AM
By reducing the vacuum, so that the differential pressure across the diaphragm does not exceed the maximum allowable?
07/31/2012 10:48 PM
But this differential pressure will exist even when turbine is running normal since condenser is still under vacuum. So why doesnt this diaphragm fail during normal running?
Thanks in advance
08/01/2012 3:28 AM
Somewhere in the original equipment manufacturer's user manual there will be a detailed process description. What does it say?
And if it doesn't say, what does their technical helpline have to say about it?
Register to Reply 3 comments
