Previous in Forum: Digsilent Current Waveforms and High Impedance Faults   Next in Forum: 15 Watt Solar Panel- Bilge Pump (No Battery) Shut Off and Turn on Automatically?
Cable Laying Procedure
07/31/2012 7:36 AM
Dear sir,
I have 7 nos of temperature sensors in different locations. I used 1Px1.5sqmm cable for connecting sensor to the PLC. Actually the PLC panel location is far away, approx 200m. So a junction box is installed and all the 7 sensor cable are terminated in the junction box.
Now, the question is from the juntion box to PLC, whether I have to lay 7 Nos of 1Px1.5 sqmm cable or Can I use 10P or 12P x 1.5 sqmm cable?
Can I use multipair cable to club the analog signal from the sensors?
What are the practical difficulties, if I use 12P cable for reduce the number of cables? Is any other possible way or any standard procedure, please kindly clarify.
Regards,
Kailash
Pathfinder Tags: cable
Re: Cable Laying Procedure
07/31/2012 7:39 AM
The above description reflects the use of multipair cables elsewhere. Go for it.
07/31/2012 8:39 AM
If one were to run 7 individual cables back to the PLC, then one wouldn't need the junction box.
Good Answers: 102
08/01/2012 3:28 AM
That depends on the availability of it at your location.
Are you really using 1Px1.5mm2 or is it really 2x1.5mm2?
Register to Reply 3 comments
