Previous in Forum: Cable Laying Procedure   Next in Forum: Reducing Transformer Losses
13 comments
15 Watt Solar Panel- Bilge Pump (No Battery) Shut Off and Turn on Automatically?
07/31/2012 11:39 AM
An electrical engineer told me Sunday that my gravitational vortex power plant demo should be just fine and would come on automatically in the morning and then shut off at night. It was powered by a 15 Watt solar panel that ran a 600 gallon per hour 12 volt bilge pump (with 3 amp fuse inside) so I guess it was a 25 or 30 Watt pump.
It was going slowly but worked really well for the demo. Just the right speed. Also when people shaded it, it went off but came on again when they moved.
Anyway, could anyone confirm what he said? Or maybe it needs a capacitor or something somewhere to shield the motor from low power in the morning, evening cloudy weather?
I think it might be a super way to power small pond features and if people included the vortex, it can also power little water driven "wire men" or "wire man riding a bike" (I joked about a gyrating go go girl instead) made of wire above the vortex as part of the water feature. http://www.youtube.com/watch?v=ZPh4GymUGSg Thanks
Brian
Re: 15 Watt solar panel- bilge pump (no battery) shut off and turn on automatically?
07/31/2012 11:46 AM
It's sort of fail safe I'd think.
If there isn't enough light to power the motor, then there isn't enough light to produce enough current to burn out the motor which has stalled due to low volts either.
If you want to be sure you need to provide the motor and solar panel spe'c and/or take some measurement.
My gut feel says you are ok though as it's all pretty low power and the solar panel is under-rated anyhow.
07/31/2012 12:05 PM
Dear sir,
I think that your system is OK.
I have used solar panels to power a 1/4 HP water pump, and when there is not enough sunlight the system just shuts off. Between the solar panels and the pump there is a VFD, when the VFD has not enough power to drive the electric motor it stops it.
When there is enough sunlight again the systems restarts.
As you are using a 15 W solar panel, less power no VFD, but the concept is the same, the system will work fine.
Best regards,
Jorge.
07/31/2012 12:17 PM
I vote for, "a gyrating go go girl".
07/31/2012 5:52 PM
Sadly and regretfully, LynDoor™ Industries cannot tender a price offer for a gyrating go go girl ornament.
Our head of R&D, Nancy the Welder, has struck out on a private venture. The entire LynDoor™ Industries G4 Division has collapsed in her absence.
Good Answers: 123
08/02/2012 8:37 AM
Does that also kill off the pole dancing "lady"? Based on the findings in post #11, there is an open market for this.
Bob
08/02/2012 9:59 AM
There is, we believe, quite a large unfulfilled market segment of Gyrating Go-Go Girl ornament consumers.
Our G4 Division was one of our most profitable segments, grossing nearly $8 USD per quarter, the tertiary market (as we are discussing here) outpacing the secondary market by 3 to 1. A Gyrating Go-Go Girl ornament, being a discretionary luxury purchase item, has essentially no primary market.
Hmmmnm... Pole dancing lady... you may be on to something here. At the next LynDoor™ Industries board meeting (scheduled 29 February, East Undershirt, AK), I will bring this up for discussion and possible action. There may be a little something extra in your pay envelope for this useful suggestion!
07/31/2012 12:19 PM
It's not going to get any hotter than if it were left on its own out in the sun.
07/31/2012 12:25 PM
So shooting water into a bucket at an an angle and making it spin constitutes a gravitational vortex now?
08/01/2012 12:47 AM
No, but it is a decent demo.
Lots of people liked it and lots of people came back for a second and third look.
Good Answers: 804
Re: 15 Watt Solar Panel- Bilge Pump (No Battery) Shut Off and Turn on Automatically?
07/31/2012 1:52 PM
Capacitors store energy, but release it all at once (ignoring "super caps" that you can't afford yet). If you want this to work when shaded, you need a battery. Batteries cost money, require maintenance and you will need a charging circuit. Hard to imagine a "wire man riding a bike" being worth that much trouble.
But a gyrating go-go girl might be...
07/31/2012 11:07 PM
If a 25 or 30 watt pump powered by solar could pump 600 gallons per hour, approximately 10 litres per minute, it is quite good.
I would like to access such pump to work on my solar photovoltaic panel of 40 watt/12 V D.C. power
Could you tell me where that bilge pump was procured and its cost ?
08/01/2012 12:50 AM
I really don't know the specs. It was the lowest end 12 volt bilge pump I could buy. There are hundreds of them on the net but they only pump a couple of ft high.
08/01/2012 1:17 AM
Thanks for all the comments. I had a look but didn't find a wire gyrating go go girl online. All i found was "kinetic sculptures" http://www.youtube.com/watch?v=8QiOAg_Caig&feature=plcp
It is sort of the same idea as the kinetic sculptures but less trippy. Here is another one. http://www.youtube.com/watch?feature=player_detailpage&v=D2HF-1xjpP8 All these things need a power source and maybe the gravitational vortex can do it. It is really simple and I like how the torque just builds up if not enough power is being used.
Register to Reply 13 comments
bob c (1); Doorman (2); Gadepalli Subrahmanyam (1); gaiatechnician (3); Jorge (1); JRaef (1); lyn (1); PWSlack (1); tcmtech (1); user-deleted-1105 (1)
