Previous in Forum: Can Relative Humidity Reach 100%?   Next in Forum: Dampening Cable Vibration
Atmospheric Pressure vs. Altitude for Dry Air?
08/01/2012 11:02 AM
Atmospheric Pressure Vs Altitude, standard data given is for Dry air or moist air? If moist air, what is the RH% considered?
Ex. Sea Level Pressure is 101.3 kPa. Because humidity is not mentioned.
Re: Atmospheric Pressure Vs Altitude for Dry air?
08/01/2012 11:17 AM
Review these standard conditions for temperature and pressure, or STP.
Engineering Fields - Control Engineering - Newby Member Long Time User Engineering Fields - Instrumentation Engineering - New Member
08/01/2012 1:51 PM
Can you provide a brief description of your application? How is this information going to be used?
08/01/2012 2:26 PM
Check out "density altitude calculations".
Not sure what you are trying to accomplish.
Re: Atmospheric Pressure vs. Altitude for Dry Air?
08/01/2012 5:41 PM
The RH of a sensor can't be used to correct the pressure vs altitude at a point, it could be 95% near the sensor and 5% 100 feet up, or go up to 1000, it has no scientific correlation to pressure outside of sensor operation itself.
The requirements of %RH for the standards that specify them is probably for sensor durability testing, linearization, or to establish an acceptable operating point.
08/02/2012 3:21 AM
Google "International Standard Atmosphere" and "psychrometric charts".
08/02/2012 4:55 AM
Dear Friend,
To my knowledge, it is neither totally dry or totally saturated air and 60 % RELATIVE HUMIDITY is considered for Air.
Let us see what other CR4 Members, express their views.
DHAYANANDHAN.S
BDThompson (1); dhayanandhan (1); Doorman (1); lyn (1); PWSlack (1); Sceadwian (1)
