Previous in Forum: ANSI B 16.5 Flanges   Next in Forum: Tonnage That U.S. Baird Multi-slides Can Handle?
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Kamag generator coupling
05/16/2007 5:23 AM
Dear All
As you know for Kamag generators we can use any numbers of drivers. I am asking way is not recommended to tie each other a flexible coupling?
Thanks in advance
Look over to the next challenge
Good Answers: 19
Re: Kamag generator coupling
05/16/2007 11:50 PM
Is this a Kato 'Kamag' generator? I don't understand your question, actually, but want to help you. Are you suggesting that Kamag is telling you 'Do not use a flexible coupling' between the driver and generator? Is this a two bearing generator or single bearing?
