Previous in Forum: Welding Rod Oven Plans   Next in Forum: Swing Check Valve
8 comments
Tin Compactor Design
08/05/2012 6:44 AM
folks any one got a design/plans for a small tin can compactor hydraulic pref? alum tins are fine but i have lots of steel cans from dog/cat food i need to flatten as easy as i can (pardon the pun) george (uk)
Re: tin compactor design
08/05/2012 7:25 AM
Dunno why you want hydraulic. A simple lever should give plenty of grunt, specially if you design it so you can pull down with your body weight.
08/05/2012 9:29 AM
What plans?
Re: Tin Compactor Design
08/05/2012 1:01 PM
08/06/2012 1:50 AM
great for aluminum cans but not a hope in hell for steel food tins, tried it, got the broken bits to prove it.Need something the Mrs can use if needs be, and though I use a sledge hammer at the moment its a pain setting up the can, flattening it and collecting them. Ideal if I hopper feed the beast and it collects in a bin or bag below. Simple ram or a piston engine driven. Checked on YouTube lots of types but again mostly for aluminum.... Could even think of using a pipe, filling the pipe with tins, compacting the lot (mini baler) and the slug coming out the bottom?
08/05/2012 7:19 PM
For steel cans expecially, first squeezing the sides a bit by hand will ease the end-to-end compression.
08/05/2012 7:50 PM
"expecially"
Ebonics?
08/05/2012 8:07 PM
Hmm, I wonder what subconscious thing could have led to that....maybe too much expresso?
08/05/2012 8:28 PM
As the question has already been answered above, have you thought about switching to bagged cat and dog food?
Register to Reply 8 comments
jack of all trades (1); lyn (2); mi3gto (1); SolarEagle (1); Tornado (2); user-deleted-1105 (1)
