Previous in Forum: Engineering Reference Tools   Next in Forum: Welding Details
India - Member - Atul Singla Engineering Fields - Piping Design Engineering - Atul Singla- INDIA Engineering Fields - Mechanical Engineering - New Member
Shelter Over Pumps
08/13/2012 10:19 PM
What are the various conditions to decide the requirement of shelter over pumps??
Atul singla
Pathfinder Tags: Shelters over pumps
Re: Shelter over pumps
08/13/2012 10:25 PM
The most important condition is common sense.
You give no indication of any potential operating environments.
You must have some idea. What do you think would cause you to shelter a pump.
Is it outside? Is it powered by electricity? Gas? Solar? Geothermal? Wind? Perpetual motion? Magic? Devine intervention?
Do you have any engineers there?
08/13/2012 10:30 PM
How much precipitation and wind?
Good Answers: 61
Re: Shelter Over Pumps
08/15/2012 4:00 PM
All of the conditions on which to decide the requirement for a shelter over pumps are closely related.
1). Geographic Location of the Plant - Is the plant located in the Arctic North or in the open Saharan Desert?
2). Weather Conditions -Is it very cold, very hot, very wet?
3). Type of Pumps -During maintenance will the pump internals and parts be subjected to even more damage because they are exposed to the elements.
4). Frequency of Maintenance -If maintenance is infrequent then a portable shelter might be considered. However if the pumps and the related facilities are subject to constant attention and one or all of the items above are present then a permanent shelter should be considered.
5). Employee Turnover -If all of the previous conditions exist and you do not spring for a permanent shelter then you may have trouble keeping trained and experienced employees on the payroll.
Do it once and do it right
Good Answers: 19
08/17/2012 12:55 AM
With a strong door with a padlock else they get stolen and to hell with wind and rain.
Register to Reply 4 comments
ducon (1); lyn (1); PennPiper (1); Tornado (1)
