Previous in Forum: Inductor Coil Design   Next in Forum: Security Lighting System Fault Tracing
Power Factor
08/15/2012 7:42 AM
what happens to a generator if the power factor of load suddenly increases or decreases??
barath.shekar@gmail.com
Re: Power Factor
08/15/2012 8:27 AM
If the current flowing to the load is less than the generator's overload trip setting, then all that will happen is that the consumption of energy from the prime mover will change as well.
If by changing the power factor the current rises above the trip setting, the trip will operate and disconnect the generator from the load.
Re: Power Factor
08/15/2012 11:16 PM
It is worthwhile to record frequency Vs pf.
pnaban
Good Answers: 42
Re: Power Factor
08/15/2012 11:46 PM
Read the link below to get a better idea as to how pl of the load affect the generator.
http://www.cashmanequipment.com/UserFiles/Uploaded/cms/generator-power-factor.pdf
and link below for effect of leading pf on generators.
http://www.cumminspower.com/www/literature/technicalpapers/PT-6001-ImpactofPowerFactorLoads-en.pdf
Register to Reply 3 comments
pnaban (1); PWSlack (1); V.I.Abraham (1)
