Previous in Forum: How to Check Ohms Resistance   Next in Forum: DO WE NEED 25 SYN. CHECK RELAY IF SAME TRANSFORMER APPLIED
Back Feed from the Neutal Wire
08/20/2012 6:29 PM
i asked this ? a few days ago. i'm reading 2. 5 v from the neutral wire to ground in the receptical boxes on my camper. should i use a ground stake?
all the breakers "3 cheaters" are running off one side of the entrance box.
could this be the the problem?
This discussion was "closed" on 08/21/2012 10:07 AM. No new comments are allowed.
Message from admins:
This discussion has been closed. Please refer to this link for further comments. http://cr4.globalspec.com/thread/80007 CR4 Admin
Re: back feed from the neutal wire
08/20/2012 6:36 PM
The system is 12v or are we talking mains? If you want to see if the voltage is real or just residual induced flow check it by putting a load on it.....2.5 v with 0 amps is ghost voltage....I would balance the load, but if you have sufficient capacity feeding the breakers, it's not a problem...
08/20/2012 6:56 PM
I think you have to much time on your hands and not enough real problems in life to worry about.
If not there are some really good medications today that make such fixations less fixating if you know what I am saying.
08/20/2012 8:43 PM
do you consider an electrical problem in a living area as something i should just ignore?
CR4 ADMIN: Modified Post
Abuse/Attack: This post was modified because it was an attack on another user. Please review the CR4 Site FAQ and the CR4 Rules of Conduct.
08/21/2012 6:25 AM
<...an electrical problem in a living area...just ignore...>
This particular one? Definitely.
08/21/2012 8:50 AM
I definitely recommend the meds now!
Maybe a tranquilizer dart or too as well.
"don't ever slander me again. your obviously an egotist looking to satisfy your own pathological needs."
Careful now talk like that may just make you my new online hobby!
08/20/2012 8:53 PM
Re: Back Feed from the Neutal Wire
08/21/2012 3:27 AM
No, there isn't a problem, as indicated a few days ago with reasoning at that time.
http://cr4.globalspec.com/thread/80007/Home-Wiring
Register to Reply 7 comments
jlstitt2 (2); PWSlack (2); SolarEagle (1); tcmtech (2)
