Previous in Forum: Voltage and Current Harmonic Distortion   Next in Forum: Solar Controller
12 volt tap getting hot
08/21/2012 1:00 PM
i am trying to put 12 volt lights on my golf cart and tapping off the main batteries at 12 volts ,but the wires get hot real fast . using 16 ga wire
Good Answers: 125
Re: 12 volt tap getting hot
08/21/2012 1:05 PM
Possibilities:
1. Your wire is too small for the load you are trying to operate...choose a larger wire size.
2. You have a short somewhere in your system...verify amperage draw using amp meter and compare actual draw with design draw of lights.
08/21/2012 1:08 PM
What wattage are the lights? 16ga wire is max @ 25A....that would be 300W....could be a bad connection...check the amp draw with your ampprobe...Are you sure it's a 12 v connection ?....Golf carts are generally 36v or 48v...
08/21/2012 1:26 PM
I used the first 2 6 volt batteries for the tap, and i will use 8 ga. wire to the bulbs
08/21/2012 7:06 PM
Many golf carts have 8 volt batteries. Are you running 2 wires or using the chassis as ground. Make certain you have 12 volts to ground. 16 ga wire should be sufficient for one headlight, 12 ga if you run both lamps from 1 wire
08/22/2012 4:44 AM
Make sure there is a suitable circuit protective device that will disconnect on over-current!
JWthetech (1); PWSlack (1); saveone12 (1); SolarEagle (1); WJMFIRE (1)
