Previous in Forum: Co Boiler   Next in Forum: Sight Glass Fitting
Heat Exchanger
08/22/2012 1:49 AM
what is the function of seal rod and sealing strip in heat exchanger ?
Re: HEAT EXCHANGER
08/22/2012 4:41 AM
Leak prevention.
Re: HEAT EXCHANGER
08/22/2012 5:30 AM
Kindly read various leakage stream(A,B,C,E,F) in shell side of heat exchanger.
A stream - Tube & Tube hole in baffle
B stream - mail stream
C Stream - Bundle & shell - can be reduced by sealing strip
E stream - baffle & shell clearnce
F stream - passlane width -canbe reduced by seal rods
B Stream
Main heat transfer stream, follows a path around baffles and through
tube bundle; most effective stream for heat transfer
A Stream
Leakage stream, flowing through clearance between tubes and holes
in baffles; effective for heat transfer because it contacts tube surface
C Stream
Leakage stream flowing over bundle, back and forth through
exchanger in clearance between tube bundle and inside of shell;
partially effective because it contacts bundle's outside surface
E Stream
Leakage stream flowing the length of the shell between outside of
baffle and shell; not effective for heat transfer because it does not
contact tube surface
F Stream
Leakage stream flowing back and forth between baffles in passlanes,
present for units with more than 1 tubepass; partially effective
because it contacts part of the heat transfer surface (added to
Tinker's theory by Report S-SS-3-1)
Re: HEAT EXCHANGER
08/22/2012 6:20 AM
thanks
Anonymous Poster (1); Mitul (1); PWSlack (1)
