Previous in Forum: Bending SS316 Thickness 3.0 mm   Next in Forum: Concentric Reducer
15 comments
Gearbox Company Names
08/22/2012 11:32 PM
Dear friends
My company is looking for a planetary gearbox supplier with products comply with the following specifications:1. Power ranges from 2500KW to 10000KW.2. Speed increaser3. Input speed: 1500rpm and output speed from 4800rpm to 12375rpm.
I guess it is not the right place to post this kind of question, but what I need is only the company names. I have been working on this for couple of months but with very limited feedback. Hope you guys can help me out.
BTW, is it allowed to post email address here?
Thank you
Pathfinder Tags: gearbox manufacturer planetary
Re: Gearbox company names
08/22/2012 11:52 PM
08/23/2012 1:44 AM
I have checked there, but most of the products listed there are only smaller sizes. There were some companies provide high power, and I have contacted them, none of them fit my criteria.
08/23/2012 1:50 AM
I would phone just about any gearbox company and ask if they offer what you need. If not, they may know of another manufacturer who does.
08/23/2012 2:05 AM
Thanks mate. I did make phone calls, but most of them produce speed reducer, so do the company names they told me.
08/23/2012 3:42 AM
Speed increasers may not be especially common. If possible, it may be better to enlarge the driven component so as to operate at the slower prime mover speed.
(I once designed refrigerant screw compressor packages each way, and it turned out that the larger/slower compressor was better on all counts of cost, maintenance, noise, and longevity.)
08/26/2012 9:16 PM
It is a brilliant thought, but that would cost a lot of time on discussion about the ideas, design and cost calculation.
Good Answers: 58
Re: Gearbox Company Names
08/23/2012 9:13 AM
Try calling a gear manufacturer and talk to someone in their engineering department or try a gear manufacturers association and perhaps they can point you in the correct direction.
Good Answers: 102
08/23/2012 11:22 PM
That's thousands of horsepower!!!!
Is this a ship or a locomotive or something like that?
08/23/2012 11:26 PM
yep, that's a big thing. it's going to be connected with a centrifugal compressor.
08/23/2012 11:49 PM
Would a 2-pole (3000 rpm) motor, with a somewhat larger compressor, be workable?
Good Answers: 102
08/24/2012 1:23 AM
Have you looked at Benzlers yet?
They do custom boxes.
08/24/2012 6:51 AM
Were you from? I am waiting reply from firm in Czech Republic. They produce many gear boxes. Best regards Libor Pirko
08/24/2012 7:17 AM
The company is ready for producing. Please send more information for detailed offer. Regards Libor
08/24/2012 10:20 AM
Thanks a lot. here is the specification.
Planetary gearbox
Connection position Motor driver on the side of the flange plate
Power:10000kw
Input Speed (rpm) 1500
Output Speed (rpm) 12375
gearbox fixed on the side of the motor driver
08/24/2012 10:29 AM
If is possible send me private message with contact information.
I give them. Regards Libor
Register to Reply 15 comments
KJK/USA (1); lyn (1); peterzgn (5); Pirko (3); Tornado (3); Wal (2)
