Previous in Forum: Are You Aware of Nanocellulose?   Next in Forum: Overall Heat Transfer Coefficient
23 comments
Chemically Heating Water
08/24/2012 4:39 AM
Is there a way to chemiclly heat water and the water still be safe for drinking?
Re: Chemically Heating Water
08/24/2012 4:57 AM
C4H10 + 61/2O2 → 4CO2 + 5H2O
ΔH = −2.8781 - −2.8769 MJ mol−1
08/24/2012 5:22 AM
Is that a formula to heat drinking water?
08/24/2012 5:40 AM
It is a formula to produce the heat for drinking water.
08/24/2012 8:26 AM
If you knew precisely what you were doing and had the right measuring equipment you could combine sodium hydroxide and hydrochloric acid. This will cause an exothermic reaction and could bring the water to a boiling point if enough of the acid/base materials were used. The result would be salty water. It would be drinkable, but you'd have to remove the salt (somehow) if you needed this water to survive on.
A better option would be to keep the two sets of liquids separated. Put the water you want to drink into a bottle and tightly seal it, then place this into the vessel where the chemical reaction takes place. Once the reaction is done remove the hot bottle with tongs, carefully uncap it, and pour out the clean hot water.
08/24/2012 8:52 AM
See I have an idea but the product has to be safe and easy enough for consumers. Like your everyday soccer mom even.
Good Answers: 104
08/24/2012 8:59 AM
OK, what's your idea?
08/24/2012 9:04 AM
My advice is to consult with the FDA. They will be more than happy to point out the folly of chemically treating water and then having them approve it for human consumption.
Stick with a safer solution.
See larger image and other views
05/31/2013 3:31 PM
... And let us not forget, that putting a kettle of water over an open flame is indeed a chemical way of heating water.
Yes, fire is a chemical reaction...
Exothermic Oxidation - if you wanna callit something
Sort Of Heating Water Chemically
08/24/2012 11:26 AM
Is your idea something along the lines of a flameless ration heater already in use by people around the world to heat water and food?
Re: Sort Of Heating Water Chemically
08/24/2012 11:44 AM
Will water that is microwaved with 12V kill you, too?
Soccer moms will love this.↓ This will give them yet another distraction, while driving the kids to the soccer match.
12V Microwave 12 Volt Wavebox
08/24/2012 12:01 PM
Yeesh! 660 watts @ 120VAC, 240 watts @ 12VDC... 20 amps @ 12VDC?
So... does it come with a carton of fuses? How long would it take to boil a cup of water at 240 watts? Can you water the plants with water boiled (eventually) in a microwave powered at 12VDC?
08/24/2012 9:46 PM
I dont mean to be secretive. but its something that noone is using yet and it has the potential to be very big and very profitable. Does anyone know how i would go about getting a patiant?
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
08/24/2012 11:41 PM
How about a PATENT instead of a patiant?
Hhhmmm, you appear to starting off on the wrong foot here.
Do you have formal training in science or engineering?
Speak softly and carry a big stick.
08/25/2012 10:38 PM
Sorry no i dont.
But I am smart with a good idea an I carry a big prick!
Does that count? O y am i asking? "I dont CARE"!
Thanks
Good Answers: 50
08/26/2012 1:25 AM
It's wonderful that you have a great idea.
You will discover, however, that being a smart*%# with an attitude will get you nowhere in these forums.
As you have seen, people have offered suggestions and help.
Chill a bit, and you'll see that things will be easier on you, and the help will come.
08/26/2012 7:42 AM
Really?
<sigh> Yet another fresh member carrying a belief that rudeness will be rewarded.
See ya around, Rob. [Doorman unsubscribes from another unfolding tragedy]
Good Answers: 102
08/25/2012 1:31 AM
Why boil the water to make it potable?
Off the shelf water purifying tablets would do it. Easier and safer than carrying around reagents just waiting for the chance to get it on together in a blistering tango.
ETC ETC
Good Answers: 120
08/25/2012 3:36 AM
Self heating soup, tea and coffee have been featured in movies. The same method will heat water.
These one use the heat of hydration when you slake lime in an inner compartment to heat the soup/tea/coffee in 3 minutes.
Hot drinks-soups
Hot-Can-Tomato-Soup
Per Ardua Ad Astra
Good Answers: 102
08/25/2012 4:00 AM
Good Answers: 109
08/25/2012 5:46 PM
How about gamma irradiation? If that is not heating the water quick enough, you can even try UV with excess flux. How much heat do you want?
Technical Fields - Architecture - New Member Popular Science - Weaponology - New Member Popular Science - Paleontology - New Member Engineering Fields - Automotive Engineering - New Member Israel - Member - New Member
08/26/2012 7:46 AM
Hi RobTech, I think there is a way to do all this process indeed chemically : there is supposed to be such a thing/process in Japan where they heat sake this way. Never bothered to check out-maybe you will invest some time? Best regerds and luck.
Good Answers: 120
08/26/2012 9:02 AM
all the ways to heat chemically keep the food separated from the heating method. Here are some methods and diagrams to show assorted ways. Click on any diagram and close the picture to read the base page and then use the back arrow for the next one.
http://tinyurl.com/8sswmf4
http://tinyurl.com/9ga8yys
http://tinyurl.com/8cb9epq
If you neutralize an acid and a base the products must be edible, as in salt from HCL and NaOh, but to use enough hydrochloric acid and sodium hydroxide to neutralize and give a hot drink item would leave it too salty to drink.
other acid base pair would be very toxic. NaF and NaOH for example.
an acid base pair in the heating capsule would work and would make more heat than the CaO - water heating capsule, but dry lime and water are easy to contain with little risk of corrosion caused leakage. And strong acid and base combination would require some corrosion resistance in the encapsulating means = $$ as well as risk.
Any self combusting heating wick would make toxic fumes
Per Ardua Ad Astra
08/27/2012 5:28 PM
Calcium oxide could be mixed with an excess of highly carbonated water.
The result would be heated water with some calcium carbonate and a little calcium bicarbonate.... effectively heated hard water.
Register to Reply 23 comments
aurizon (2); bigg (1); Doorman (3); kevinm (1); lyn (2); Night_Manager (1); PWSlack (2); RobTech (4); standarded (2); truth is not a compromise (1); Usbport (1); Wal (2); Yuval (1)
