Previous in Forum: Chiller Problem   Next in Forum: Turbine Gearbox to Generator
Smoke from VFD
08/26/2012 12:10 PM
Dear Friends,
I have a proble of frequent failure of FVD, like smoke from VFD and IGBT getting failed, but I am using the Higher size VFD for normal induction motor, i am also using the line chocker, the dc bus voltage is also not more than 600, what might BE the possible causes for the failure the VFD. PLEASE HELP ME TO SORT OUT THE PROBLEM.
Good Answers: 34
Re: Smoke from VFD
08/26/2012 2:00 PM
I am unable to paste a link. If you google: troubleshooting vfd drives
you will get lot of info for a start.
By the way could some friend advise how to put a hyperlink to these posts.
Good Answers: 18
Re: Smoke from VFD
08/26/2012 2:41 PM
Hi Joshi,
I believe if you copy & paste into your post you will be able to include the hyperlink - it works for me!
Good luck,
Regards,
Keith
A little knowledge that acts is worth infinitely more than much knowledge which is idle! Khalil Gibran
Good Answers: 34
Re: Smoke from VFD
08/26/2012 3:31 PM
Thank you, Keith.
I will try again next time. The tool bar is getting de-selected to use hyperlink button on my computer.
Re: Smoke from VFD
08/26/2012 4:44 PM
Aside from guessing all application info, anachronyms and how device(s) are determined failed - you're preferred course of action after frequent fails is to do the same thing over again and post this? Really?
Truly failing a VFD is a difficult enterprise to undertake. You need someone who can review your application and properly configure the drive. 'Like smoke' = someone who should stay far, far away from this.
Re: Smoke from VFD
08/28/2012 4:37 AM
Three sorts of people are needed to solve the problem.
  • A qualified electrician, who needs to examine, test and rectify any problem with the wiring either side of the VFD, and
  • A qualified service technician, preferably from the company that manufactured the VSD, to carry out whatever repairs are needed and to cover the facility with a warranty on those repairs to the equipment, and
  • A financial controller, who is able to authorise the budget needed to pay the two types of people above.
Good Answers: 19
Re: Smoke from VFD
08/31/2012 11:32 PM
http://est-aegis.com/TechPaper.pdf
Preventing VFD/AC Drive Induced Electrical Damage to AC Motor Bearings
drmilr (1); ducon (1); Joshi (2); Keith Grewar (1); PWSlack (1)
