Previous in Forum: Solar System in India   Next in Forum: Spade Plugs and Terminal Fittings
12/2 Braided Wire
08/26/2012 9:27 PM
what' the the max. amp fuse i can use for 12/2 braided wire @12- 13.5v.
Re: 12/2 Braided Wire
08/26/2012 10:24 PM
I think the NEC says 20A. (The theoretical ampacity is higher, but a footnote contains this limitation.)
Good Answers: 445
08/27/2012 11:55 AM
It depends on a number of factors but an insulated conductor in air has the temperature rise vs. insulation material as the limitation. Is this for AC or DC? Here's a chart for 12V, length vs. wire size:
http://www.engineeringtoolbox.com/amps-wire-gauge-d_730.html
...and it accounts for voltage drop.
Here's another that's for auto wiring:
http://www.hotrodsandclassics.net/usefulinformation/wireandfusequide.htm
Good Answers: 44
08/27/2012 5:23 PM
Can use or should use?
Register to Reply 3 comments
cuba_pete (1); RAMConsult (1); Tornado (1)
