Previous in Forum: 6.6 kV and 11 kV Transmission Line   Next in Forum: Underground Cable Laying
Hydropower Plant 2*1650 kVA
08/28/2012 7:04 AM
Hi,
For our 2*1650 kVA hydropower plant in Nepal, what could be the rating of intake supply transformer, and as, 6.6 kv and 11 kV both are present - the generator voltage is 6.6 kV and stepped up to 11 kV. From which voltage side should the supply be taken for the distribution transformer for intake site? What could be the rating for intake transformer? In my opinion, the station transformer should be around 135 kVA, and the intake transformer should be around 350 kVA for 30 ampers of load at 6.6 kV. For 11 kV, for 30 amperes of load, the kVA rating will be higher.
Regards,
sks
Good Answers: 181
Re: Hydropower Plant 2*1650 kVA
08/28/2012 7:39 AM
Are we talking about the supply required from the grid for plant start up? If we are take it from the grid voltage. If not please explain a bit more.
08/28/2012 10:06 AM
<...From which voltage side should the supply be taken for the distribution transformer for intake site?...>
What are the available voltages?
Is it time to farm-out the job to a local specialist instead of designing it with a CR4 Committee?
Good Answers: 181
08/28/2012 1:19 PM
We'd have to farm out sauravbabu's imagination, it's the only place this power plant exists.
Register to Reply 3 comments
