Previous in Forum: Coiling of Cables in Modularized Project.   Next in Forum: Best Luminaire for Control Room
Lightning Areaster Down Conductor
08/29/2012 2:41 AM
As per IEC62561/IS2309 the down conductor for lightning areaster-can we run inside the shaft(not in electrical shaft).If no what is the reason?
Pathfinder Tags: Down conductor
Re: Lightning areaster down conductor
08/29/2012 3:12 AM
If the conductor fails during a lightning strike event, is it better for the explosion to happen inside the building or outside <rhetorical question - NNTR>?
Re: Lightning Areaster Down Conductor
08/29/2012 5:31 PM
Quote "As per IEC62561/IS2309 the down conductor for lightning areaster-can we run inside the shaft(not in electrical shaft).If no what is the reason?
What do you mean by shaft? Are you referring to metal conduit?
08/30/2012 12:31 AM
In high rise building Shafts are used to run the plumbing line/Electrical cables from lower floors to upper floors to distribute the services in all floors.People are mentioning as plumbing shaft, Electrical shaft.
08/31/2012 12:04 AM
dependable lightening earthing involves directing the high voltage through a good conductor that is the shortest path to a good ground and away from people and equipment. high voltage from a lightening strike will aways take the path of least resistance. the voltage involved is capable of jumping from a ground to a better ground.
Register to Reply 4 comments
durtieduck (1); Muthuvel (1); PWSlack (1); wareagle (1)
