Previous in Forum: Bearing Number   Next in Forum: MS Reducer
14 comments
Chilled water quality
08/30/2012 4:31 AM
We use soft water (Hardness < 5 ppm) for our closed loop chilled water system with soft water make-up facility and Chemical Nalco R-39 M.
We just change the water 45 days ago but suddenly today we find TDS: 450 PPM, pH: 8.81 & Hardness: 17 PPM. Is it good enough or we need to take any precaution?
I try in the Google for any reference for closed loop chilled water system but did not get any authentic papers! So, if any body help me to find any reference.
Experiance will come with time, but you have to manage quality time. Bad management always leads us bad experiance.
Re: Chilled water quality
08/30/2012 4:32 AM
How did the telephone call to Nalco go?
08/30/2012 4:41 AM
Nalco local supplier is not so helpful (in this regards ).......
08/30/2012 4:52 AM
Comment withdrawn on edit.
08/30/2012 4:55 AM
Then the answer is that it depends upon the quality of the heat exchange surfaces that the water is being used to cool and upon the temperatures it is being used to reduce. Maintain the chemical dosing regime and involve Nalco with the data over time.
08/30/2012 10:45 PM
we are looking for closed loop chilled water quality standard ............
08/31/2012 12:43 AM
it could be caused by galvanic current from two dis-simular metals that's causing one to errode.
ground all dis-simular metals near all the joints.
you might need to add sacrificial metal to the ground wires.
good luck
08/31/2012 2:25 AM
are you using distilled water?
08/31/2012 10:22 PM
Soft water ....................
08/31/2012 1:29 AM
There is ingress of foreign matter or chemical used is not genuine.
08/31/2012 8:24 AM
  • How many years old chillers
  • How many hours operation per day
  • How many days in a year
B.E, M.I.E, M.S
08/31/2012 10:19 PM
Q1: 3 Y
Q2: 12 Hrs
Q3: 340-345 Days/Y
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
08/31/2012 9:29 AM
Assuming you don't have a leak into the closed loop, have you checked the operation of the upstream water softener facility? As others mentioned, you can foul your heat exchange surfaces if you aren't careful but this is dependent on the water chemistry and not a normal standard. Higher pH will tend to encourage precipitation of calcium won't it?
Money doesn't talk, it screams in your face.
08/31/2012 10:21 PM
Soft water quality checked online (24 Hrs)..........
08/31/2012 10:33 PM
We have no confusion with the soft water quality or chemical dosing. Hardness & TDS increase may be due to the pipe corrosion. We are planning for chemical cleaning of the hole system then refilling of the total system.
What we are urgently looking for closed loop chilled water quality standard (like ASHRE, ASME etc) that we can plan for it and incorporate it in our SOP.
We are using HITACH & Trane air cooled chillers, and HE material is SS, So we need to take steps ASAP.
Thanks all of you
Register to Reply 14 comments
bashir01219 (6); betomachine (1); durtieduck (2); guruhsingh (1); Mushtaq Hussainh (1); PWSlack (3)
