Previous in Forum: Chilled water quality   Next in Forum: Drop Pressure for Cracked Gas
MS Reducer
08/30/2012 11:22 AM
I Have 2000mm Dia & 1500mm Dia pipes. I want to joint it. How could i joint it. How to reduce 2000mm pipe to 1500mm. Plz tell me.
Re: MS Reducer
08/30/2012 11:36 AM
Here are some ways:
  • T-joint
  • Concentric reducer piece
  • Eccentric reducer piece.
  • Interposing orifice plate
  • Etc.
The piping standard appropriate to the line size, class, temperature, pressure and nature of the contents will determine the correct way to go.
Consider the need to join them in the first place and whether it is better to replace the one size with the other size size: if 1500mm is the correct size for the flow, for example, why go to 2000mm and vice-versa <rhetorical question - NNTR>?
Good Answers: 19
Re: MS Reducer
09/02/2012 12:56 AM
Cut with gas cutter at end of 2000mm pipe 6" length from end x 8 nos all around . bang them all around till you get the 1500mm dia. Weld the cut lengths . The 2000 mm now will look like a reduced 1500 mm dia. Weld it on the 1500 mm pipe. If you cannot understand this tell it to your fabricator.
Re: MS Reducer
09/02/2012 3:06 AM
All answers received are valid and usable. Only the user needs to determine the purpose and medium that is being used. If flow needs to be laminar , example for instrument attachment, I would recommend that you follow the industry standard attachments in the market like the concentric reducer ( all vertical pipes) and eccentric reducers ( for horizontal pipes, installed depending on the flow medium). This would definitely give you laminar flow ( lower Reynauld's Number).
Welding the reduction is definitely a quick way for fast solutions, but there is a problem of incomplete weld penetration and rough internal surfaces that would give room for future leakages and affect flow characteristics.
Good Answers: 19
Re: MS Reducer
09/02/2012 4:01 AM
http://www.teekaycouplings.com/products/p26reducerflange.html
As Satish mentioned. You can contact them for 2000 mm x 1500mm Reducer
Register to Reply 4 comments
ducon (2); PWSlack (1); Satish Menon (1)
