Previous in Forum: Lithium Batteries   Next in Forum: Magnetic Starter for Air Compressor
14 comments
Capacitors
09/02/2012 7:26 PM
how do i test for a bad capacitor?
Re: capacitors
09/02/2012 7:31 PM
There are a number of ways, some of which are as follows
1) Visual inspection
2) Use a multimeter with a capacitance setting
3) Using a test circuit, a voltmeter and the capacitor charge and discharge formulas
4) Using a variant of the Wheatstone bridge to check a capacitor
Try an internet search of "capacitor test" form more information, as there is a lot of information available on the internet.
Re: capacitors
09/02/2012 8:20 PM
The problem is that usually the capacitors you want to test are installed in malfunctioning or nonfunctioning piece of equipment.
As such, the capacitors in question are typically not isolated, so using a multimeter or wheatstone bridge won't help.
There is a reliable method for diagnosing a bad capacitor in malfunctioning electronics. Answer the following questions:
1. Is the malfunctioning device free of things like signs of arcing (mostly on circuit boards), blown fuses, dead batteries, absent power supply, evidence of blunt force trauma, and/or dripping water?
2. Does the device have one or more electrolytic capacitors?
Yes to both? Currently have a Bad Capacitor. Look for swelling.
Yes to #2? Bad capacitor... if not now, eventually.
Re: capacitors
09/02/2012 8:52 PM
thanks guys, both ga's from me.
Re: Capacitors
09/03/2012 5:45 AM
to find the capacitor is good or bad, simply put the capacitor probes into the socket and switch it on for 1sec and after that remove the probes from socket and try to touch one probe with other probe, on touching it generates some spark ( discharging the charged current). If it is not generated any spark then it is a bad capacitor other wise it is good capacitor
Re: Capacitors
09/03/2012 3:37 PM
This can work in some cases but it would be much better to use a multimeter set to voltage setting to see if the capacitor is holding a charge (provided by a battery or similar extra-low voltage DC source).
Surely you have access to a multimeter durtieduck .
Re: Capacitors
09/03/2012 8:08 PM
yes, ihave a multimeter, but i was'nt sure how to charge the cap without using high voltage.
Re: Capacitors
09/03/2012 11:12 PM
You can still use extra-low voltage (for example 12V DC).
The results are less accurate if it is a high voltage low capacitance capacitor but will still give you a good (and safe) indication.
Re: Capacitors
09/04/2012 6:58 AM
When you say high voltage I'm thinking you want to check a start or run cap. You can use your ohm meter. The leads from the meter will charge the capacitor. Start at the 1k setting. Read the meter will show low numbers to higher numbers until the capacitor reaches saturation then the numbers will drop to 0. Then reverse the leads and check again. If its leaking the numbers will go up but won't return. Open will read infinity. Shorted will read 000. If the capacitor has a resistor across it you will have to disconnect it first or you will be reading the resistor. Remember what Mike said always short the cap in question across the terminals with a well insulated screwdriver for safety sake. Hope that helps.
Don't panic, and never give up.
Good Answers: 58
Re: Capacitors
09/03/2012 7:35 PM
If this capacitor has terminals for quick disconnect, it's fairly easy. First short out the cap with a load resistor, a nice big one, don't hold it in your hand, it'll get hot.
If you don't have a resistor, short it out with metal, but be careful, some caps can hold quite a wallop.
Once discharged (which usually means the cap is good) take an ohm meter and check for resistance. The meter should jump, and then settle down to no reading. Then reverse the leads...the meter should jump the same amount again, and settle down. This shows a good cap, usually.
If the cap is soldered onto a board, you usually have to remove it for testing. The same test applies. Be careful un-soldering it, discharge it first. Like mentioned, a swollen cap is bad, the little cover on the top bulges at the score marks.
If you're going to be fussing with electronics, get a cap tester, and an ESR tester.
mike k
Re: Capacitors
09/04/2012 9:01 PM
Sorry Mike. I didn't mean to rain on your parade. I didn't read all the comments before answering. It is consoling to know that we are on the same page.
Good Answers: 58
Re: Capacitors
09/05/2012 9:08 AM
No problem, happens all the time. I'm sure I do it, too.
mike k
Re: Capacitors
12/02/2015 3:23 PM
In-circuit power-factor-caps (Kvar) Measuring method tips are needed.
Practical electricians uses current tables in correlation for it's condition.
Can one put some light on the subject?
Thank you very kindly
10 Eliyahoo Berlin Street TLV
Re: Capacitors
09/03/2012 8:20 PM
this may seem a bit off subject, but does anyone remember charging a car ignition cap from a spark plug wire, then tossing it to some innocent soul to catch it?
Good Answers: 11
Re: Capacitors
09/04/2012 12:01 AM
Electrolytic capacitors nearly always fail open. So a quick check is to parallel another capacitor that has the capacitance that the failed capacitor had.
Of course this doesn't work for other type capacitors. Don't know if it works for tantalum capacitors or not.
Register to Reply 14 comments
Carl Pugh (1); durtieduck (3); jack of all trades (3); lmmk (2); mike k (2); santoshvarma (1); truth is not a compromise (1); user-deleted-1113 (1)
