Previous in Forum: Water Solubility   Next in Forum: Scale in Turb
Gas Turbine Design / Engineering
09/04/2012 12:21 PM
Who are the biggies in aviation gas turbine design / engineering operating out of the states? I am looking for engineer services companies.
Thanks!
Pathfinder Tags: Gas turbine
Good Answers: 125
Re: Gas Turbine Design / Engineering
09/04/2012 4:41 PM
Try Pratt and Whitney.
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Marine Engineering - New Member Engineering Fields - Aerospace Engineering - Aeromarine Vehicle Engineer
09/04/2012 6:02 PM
The other is GE Aircraft Engines out of Cincinatti, Ohio
09/05/2012 3:22 AM
Rolls-Royce?
09/05/2012 10:18 AM
Yes to all the previously mentioned - GE, Pratt & Whitney, RR
Also - Honeywell; they have taken over as OEM for the Avco-Lycoming helicopter engines (shaft power, not thrust). We use the T-53, T-55, and TF40 engines in some of our equipment.
It looks like Walter has come under GE ownership...
Register to Reply 4 comments
68SS396 (1); Gannet (1); PWSlack (1); WJMFIRE (1)
