Previous in Forum: Vaccum Sewer Systems / Consequences of Changing Isolation Valves Locations   Next in Forum: Heat Recovery Steam Generator Cleaning Method
AD -2000 : Design Pressure
09/05/2012 1:25 PM
As per AD-2000: " The static pressure caused by the contains of the vessel duringservice and/or testing need not to be taken into account as long as they do not increasethe stress of the walls by more than 5%."
Is that means that static head can be concidered only if it increases the stress in walls more than 5%?
How to check wall stress?
Re: AD -2000 : Design Pressure
09/05/2012 10:40 PM
No.
It may be considered in any case, but this is not mandatory if the static pressure adds ≤ 5% to the stress.
To check the wall stress, add the gas pressure above the liquid to the static pressure of the liquid at various depths; then apply appropriate formulas.
