Previous in Forum: Distance Relay - Quadrilateral Characteristics   Next in Forum: Shot Life of 1156 Bulbs
Sizing of Neutral Earthing Strip
09/11/2012 3:01 AM
How to size the neutral earthing strip and number of earth pit for neutral earthing
ie)for example exercise 500kVA,430V power system
Pathfinder Tags: Neutral earth strip size
Re: Sizing of neutral earthing strip.
09/11/2012 3:12 AM
One of the ways is to follow British Standard 7671.
Good Answers: 59
Re: Sizing of Neutral Earthing Strip
09/11/2012 7:15 AM
Try searching on CR4 - this question has been asked several times.
CR4 search: neutral earthing strip
09/11/2012 7:46 AM
In CR4 there is no discussion for Neutral earth strip calculation.
The discussions what they did is only for body earthing strip calculations.
Good Answers: 170
09/11/2012 10:02 AM
For 500kVA Transformer, the recommended Earth Strip Size for Neutral Earthing is:
i) 25mm x 6mm Bare Copper Strip
or
ii) 300 sq.mm PVC Insulated Aluminium Conductor
or
iii) 50mm x 6mm GI Strip
09/12/2012 12:47 AM
I know as per IS3043-1965 Annexure-D 25X6mm Cu strip or 300sq.mm Al Con
is recommended but I am asking the formula to Calculate the size .
I know the formula to size the body earthing meanwhile I need to know
formula for neutral earthing.
Good Answers: 170
09/12/2012 9:26 AM
The Standard IS 3043 does not differentiate between a neutral earthing conductor and a body earthing conductor. As per the Standard, the formula for sizing earthing conductors & protective conductors is:
S = I Root 't' / K
where,
S is the cross sectional area of the protective conductor in sq.mm
I is the fault current is Amperes
t is the fault duration in seconds
K is the Adiabatic Constant depending upon the Material of the conductor, method of laying, etc. (given vide Table 6 of IS 3043).
By the by do not refer to IS 3043-1965.
This has been revised in 1987 and amended latest in january 2010.
Good Answers: 181
09/11/2012 6:49 PM
As this is only an exercise does it realy matter?
You should do you're own research. You will learn so much more that constantly coming to CR4 to be given the answers. But you have been told this before.
Register to Reply 7 comments
electricalexpert65 (2); Muthuvel (2); PWSlack (1); SavvyExacta (1); TonyS (1)
