Previous in Forum: Suspended Support Design for Vessel   Next in Forum: Worm Gear Efficiency
India - Member - Atul Singla Engineering Fields - Piping Design Engineering - Atul Singla- INDIA Engineering Fields - Mechanical Engineering - New Member
Columns Draw Off & Return Nozzles
09/13/2012 5:24 PM
On what basis the location/Orientation of Draw off & return nozzles is fixed?
Atul singla
Re: Columns Draw off & return nozzles
09/13/2012 5:37 PM
Plant layout and piping considerations, Boss. It's no good designing the thing if you can't get it in and can't get it connected, is it?
Good moaning!
Good Answers: 61
09/13/2012 7:43 PM
This sounds like a student question.
Do it once and do it right
09/13/2012 9:17 PM
Dont think so. A text book questions is phrased differently.
Sounds like a real problem!
Good Answers: 34
09/13/2012 10:02 PM
Good Answers: 38
Re: Columns Draw Off & Return Nozzles
09/14/2012 9:32 AM
Atul,
If I understand your question correctly, you are indeed asking me how reboiler nozzle locations must be placed on a distillation column.
Joshi is correct. The overall design of a reboiler and column must be considered as a system.
Since you show no circulation pump, I assume that this is a thermally driven reboiler and therefore the nozzle locations are very important.
Because this is your first assignment in this complex area, we wish you the best of luck !
Best Regards
Good Answers: 32
09/17/2012 4:29 PM
In refinery distillation columns it had a lot to do with the condensation temperature of the various fractions (hence the name "fractional distillation column"). When too many fractions were too similar in condensation temperature the draw off was removed and reheated and sent to a smaller distillation tower to be separated into several different components where a smaller temperature range could be split up between more trays.
You probably really need a Process Engineer to give you a complete more precise answer.
Spinco
07/07/2023 7:34 AM
  • There has to be a name, or at least initials, on the drawing from which this was taken. Ask that individual.
  • There has to be a document entitled "Process Description" and another one "Control Philosophy". Find them and read them.
Register to Reply 7 comments
Anonymous Poster (1); Crabtree (1); Joshi (1); MJCronin (1); PennPiper (1); PWSlack (1); Spinco (1)
