Previous in Forum: Compressed Air Consumption Calculation   Next in Forum: Coated Nuts & Bolts - Repair with Polyurethane Paint?
22 comments
Good Answers: 12
Flooded AHU
09/18/2012 5:08 AM
We have many chilled water AHU with different sizes and different cooling capacities, some of them reserves condensed moisture outside water condensation pan where no drain line, it results for more water accumulation around blower area, it becomes full and results for water floods outside the unit through side walls and spilled on the surrounding floor
My questions, why some units like that while all others collect and drain water through the ordinary drain line for water condensation pan.
thanks in advance
don't tell me who are you , what do you know is enough.
Re: flooded AHU
09/18/2012 5:14 AM
The absence of an intended drain line, a leak or a blockage in the one that is installed are all possible causes of a problem like this. One must expect air cooling equipment to have a water waste stream, and install and maintain a suitable waste pipe accordingly.
Good Answers: 12
Re: flooded AHU
09/18/2012 5:37 AM
There is already a drain line which is connected to condensed water pan and located under chilled water coil , also it's clear and works good.
the problem is the water which condensed out side condensation drain pan
Re: flooded AHU
09/18/2012 6:04 AM
Apply thermal insulation lagging to the equipment. Something that is waterproof will do fine. Outside moist air is coming into contact with cold surfaces and condensing on them. Lagging will reduce or prevent this from happening.
Lagging will also reduce the equipment's power requirements slightly.
Good Answers: 12
Re: flooded AHU
09/18/2012 6:35 AM
the units are already isolated with double wall and thermal isolation in between.
no condense water at outside walls. but water comes from unit inside
Re: flooded AHU
09/18/2012 8:50 AM
Is there anything else that the forum needs to know?
Good Answers: 34
Re: flooded AHU
09/18/2012 5:16 AM
Consider providing proper drainage to overcome flooding & it's related problems.
Good Answers: 12
Re: flooded AHU
09/18/2012 6:23 AM
you are right. it's an easy solution .
but i would like to know why water leaves or skip condensing pan and accumulates outside in blower area
Good Answers: 104
Re: flooded AHU
09/18/2012 7:02 AM
Are you saying the condensation formed on the coil is not being caught by the pan? In other words, it is being blown past the pan? If so, it could be due to excess air flow velocity or a dirty coil.
Good Answers: 12
Re: flooded AHU
09/18/2012 7:30 AM
Dear bigg.
you are demonstrating our problem better than me. it's the right case we are facing.
are there any other probabilities for this issue
GA from me
Re: flooded AHU
09/18/2012 5:47 PM
This can be caused by oil residue on the coil causing the water to bead instead of clinging to the fins....Try spraying some low sudsing soap on the coil to increase the surfactant quality....This might take a few treatments...
Good Answers: 12
Re: flooded AHU
09/19/2012 2:32 AM
good suggestion and easy treatment
thank you
Re: flooded AHU
09/19/2012 2:23 AM
The most important is stopping the condensate from the coil to occur, the fan has nothing to do with the source of the problems. take a second look into the chilled water flow rate, entering and leaving temperature of the coil. Once these parameters are properly adjusted, hence we will have the problem solved.
Good Answers: 49
Re: Flooded AHU
09/18/2012 11:27 PM
The suggestion regarding a dirty coil is a possibility BUT- make sure that the chilled water is flowing at the proper rate.
This is a wild guess, but- if flow is low, almost ALL of the moisture removal will come from the last row or two of the coils, rather than about two-thirds of it. The easiest way to check flow is entering and leaving temperatures.
Check the specified temperature difference for the coils- it should be around 5 to 8.5C differential with entering temp around 6C to 8C entering. If you are looking at leaving water temp of 16C or warmer, you have low flow and nearly all of the cooling (and moisture removal) is happening in the final coil or two, triggering over-spray because it is flooding the face.
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
Good Answers: 12
Re: Flooded AHU
09/19/2012 2:45 AM
Dear energygod
you are a real Veteran guru
GA for U
Re: Flooded AHU
09/19/2012 1:17 AM
Check for blockage in the condensate drain line. It is very possible that all the AHUs experiencing this flooding; the drain pipes are connected together.
Re: Flooded AHU
09/19/2012 2:01 AM
Re: Flooded AHU
09/19/2012 11:51 AM
It could be a case of dirty / blocked coil. The fan is partially sucking air through the coil and because the coils are dirty the excess air is sucked from the condenstate pan through the connecting drain pipe line resulting in floods at the motor drive side.This eventually flows out and floods the area.
Good Answers: 12
Re: Flooded AHU
09/20/2012 2:04 AM
Dear pillay
very logical conception and GA
thank you
Re: Flooded AHU
09/19/2012 4:13 PM
Hi khairy: A couple of situations can cause the pan to not drain properly.
Start with the more common cause, a clogged drain line or an obstruction over the drain pan opening.
If neither of these is a culprit give a holler and I can furnish you more complicated suggestions..
Good luck.
Lou Bindner
Good Answers: 12
Re: Flooded AHU
09/20/2012 2:16 AM
Dear Binder
Drain line is not clogged. Waiting your complicating suggestion
Re: Flooded AHU
09/20/2012 4:04 AM
I am thinking about U Trap condition for condensation draining line ........ We have face similar problem and fault is with the U-trap .......
Experiance will come with time, but you have to manage quality time. Bad management always leads us bad experiance.
Re: Flooded AHU
11/29/2012 4:53 PM
This sounds like a trap depth problem on the drain itself.
Their are typically minimum distances for trap depth as it relates to the design air flow velocities. That distance is found in the installation manual and on Trane, Mcquay & Carrier units its posted to the units. It depends on the inches of water velocity of the air flow.
The reason it may be occurring on some and not others may have to do with the fan speeds occurring on some of the units.
This can be a big problem especially if the unts are not elevated on rails or housekeeping pads, limiting the distance on the trap depth.
Register to Reply 22 comments
Babs (2); bashir01219 (1); batteriesshop40 (1); bigg (1); energygod (1); Joshi (1); khairy Aish (8); Lou Bindner (1); pillay (1); pipeit (1); PWSlack (3); SolarEagle (1)
