Previous in Forum: ETAP UGS Steady State Calculation   Next in Forum: Soft Start?
11 comments
Finding Turns in Transformer
09/20/2012 11:34 AM
Question: The nameplate on a 50 kVA transformer shows a primary voltage of 480 V and a secondary voltage of 120 V.We wish to determine the approximate number of turns on the primary and secondary windings. Toward this end, three turns of wire are wound around the external winding, and a voltmeter is connected across the 3-turn coil. A voltage of 76 V is then applied to the 120 V winding, and the voltage across the 3-turn winding is found to be 0.93 V. How many turns are there on the 480 V and 120 V windings (approximately)?
Answer: With 76 volts applied, the constant is 0.93v/3T = 0.31 V/T. Correcting that for 120 volts instead of 76, that becomes (0.31 V/T)(120/76) = 0.489 V/T.So the 120 volt winding has 120 V / 0.489 V/T = 245 turns the 480 would have 4 times as many or 980 turns.
I really want to understand this question,the answer what my instructor told me is given up but he said you can use another approach to solve this question by using primary and secondary voltages and turns ratio.I dunt want to use V/T method and i wanna try other one out cuz my next test will be from other approach, i cant undertand thi part "A voltage of 76 V is then applied to the 120 V winding, and the voltage across the 3-turn winding is found to be 0.93 V".I donot know what voltage we have to use for secondary winding 120V or 76V.And can i find some voltages or current from power rating of transformer? Any solutions or suggetions will be greatly helpful.Sorry for long thread but i m new to this forum and donot know much how to communicate effectively(any suggesstions to short up my thread will also be helpful).Thank you very very much for your time.
Re: Finding turns in transformer.
09/20/2012 12:27 PM
Good Answers: 34
09/20/2012 12:37 PM
The ratio of 0.31 V per turn will apply to primary/secondary winding.
Well, I could be wrong, but the above postulate comes logically to mind.
Re: Finding Turns in Transformer
09/20/2012 2:40 PM
Answer: With 76 volts applied, the constant is 0.93v/3T = 0.31 V/T. Correcting that for 120 volts instead of 76, that becomes (0.31 V/T)(120/76) = 0.489 V/T.So the 120 volt winding has 120 V / 0.489 V/T = 245 turns the 480 would have 4 times as many or 980 turns. Can anyone please explain how you get above answer..plzzzz with formulas ,i really need to know.
Good Answers: 34
09/20/2012 3:50 PM
The worked out ratio here is 0.31 V/T
Primary turn = 1548 turns for 480 V
Secondary turn = 387 turns for 120 V
09/20/2012 10:48 PM
Your figures are correct and simply stated.
I so not see the reason for off topic, perhaps the negative posters would give some reasons??
09/20/2012 11:14 PM
Whoops sorry I made an incorrect observation.
Correction
78/245= 0.31V x 3 = o.93V
09/20/2012 10:49 PM
Right final answer, but with a superfluous "correction" along the way.
76 ÷ (0.93/3) ≈ 245 turns.
09/20/2012 11:16 PM
245...........250................251, What EVER it takes.
Good Answers: 27
09/21/2012 11:25 AM
The key information needed for any transformer computation is the turns/volt number. To get that using the information provided, we take the reciprocal of 0.31 V/T. Which will be = to 1/V/T = 1/0.31= 3.22
The turn ratio of 3.22 can now be used as the constant to get the number of turns needed for the primary, which is = 1548 truns, and for the primary which will be = 386 turns.
The KVA rating is needed to determine the proper AWG size for the magnet wire that can safely carry the rated current in amperes. It is also needed to determine the size of the core area among other things.
vsar
Good Answers: 445
09/20/2012 8:54 PM
The teacher was trying to see who really understood the concepts of turns and voltage ratios by deliberately putting multiple turns and voltage ratios into the problem.
Assuming the same transformer but instead of a 3-turn coil with 76 V and 0.93 V, he had instead said a 1-turn coil with 245 V and 1 V measured, it would have been obvious (hopefully) that both the turns and voltage ratios were 245 to 1.
The teaching problem is that if he then threw the original problem statement into a quiz only those students that truly understood the concept might possibly get it right, so in effect he was helping students such as yourself who needed a bit of assistance figure things out (see, it worked).
By the way, if you want to communicate effectively, drop the slang/texting/poor grammar and proofread your work, it will help others feel more like helping you.
Good luck in your studies.
Good Answers: 116
09/21/2012 5:22 PM
Another approach is to use the volts per turn under the test conditions...
Secondary - 76 volts at 0.31 volts/turn gives 76/0.31 = 245 turns.
Primary - must have 245 x 480/120 = 980 turns.
With a real transformer , it would be advisable to measure the primary voltage during the test. The question does not give any frequency [rated or test] or standard specification - so the turns ratio being the same as the nameplate voltage ratio is just an assumption. The name plate voltage rating could be at rated load, the zero-load voltage being higher to make up resistive & inductive voltage drops caused by load current.
For testing a turns ratio you can use any convenient voltage which is less than the rated voltage or greater by a small margin say 5%. A voltage too high could cause magnetic saturation. This could cause waveform distortion of the test source due to overloading, or distorted transformer output. Likely, the voltmeter would no longer give a true reading because input and output had different waveforms.
The basic assumption is that the same magnetic flux is passing through both windings so the fundamental equation :-
induced voltage = N x rate of change of magnetic flux. (1)
where N is the number of turns on a winding.
- is true for both windings, so their voltages must be in proportion to their turns.
Note it is also assumed that the induced voltage in the primary equals the supply voltage, so there is zero current in the primary.
In many real transformers, the assumption that
  1. all the primary flux links the secondary
  2. the primary current is zero at rated voltage, zero secondary load
is a very useful approach, although inaccurate on test or careful theoretical analysis which includes the effect of winding resistance voltage drops and that setting up an alternating flux in a transformer or inductor requires some current.
As example, I would note that I have tested two single phase 230V AC 50 Hz input transformers on "no-load", one a 24V 0.2 amp AC output "plug-top" type: the other a toroidal 30V 60 VA item in a Hi-Fi sound amplifier.
The first had 56 mA primary current, while the second was 5 mA despite being over 10 times the rating. This primary current is the "magnetizing" current necessary to produce the working magnetic flux. Note that the plugtop absorbed 3.3 watts (all heating it up) even on no-load, compared to its 4.8 watt output rating and 0.056 x 240 = 13.4 volt-amps input no-load.
The plugtop had 30V out at no-load (poor voltage regulation, no-load to rated current, due to high winding resistance) while the toroidal was about 32V.
The difference is largely that the plugtop is made for minimum cost using the minimum amount of iron and copper while the toroid is designed for good regulation of its output voltage while minimizing size and weight (and external magnetic field, which is heard as "hum" on the sound).
Register to Reply 11 comments
67model (1); Anonymous Poster (1); garth (2); Joshi (2); lyn (2); RAMConsult (1); Tornado (1); vsar (1)
