Previous in Forum: Finding Turns in Transformer   Next in Forum: '85 Ford Van " Gas to Electric"...
8 comments
Good Answers: 266
Soft Start?
09/20/2012 1:27 PM
Have an infrared oven with 57k + watts in it. Has 36 240 v 1600k watt lamps. Zoned out with 12 lamps to a zone. The zones work off sensors to product size linearly across the oven entrance. The 12 lamps are powered by one mechanical contactor. With a 3 phase 480 volt input the lamps ran in series. Two delta configuration circuits with 6 lamps on each. One circuit to the top and one to the bottom of the oven. There is no temperature control. The heat up time is controlled by how fast the product is conveyed through the oven. Switch on by sensors as the products conveyed through and shut down by timers.
I had thought about thermistor but the duration of 40 sec may not give them time to cool down.
The OEM used mechanical contactor and they do not hold up well. They were not much help when I addressed it with then.
Would a soft starter handle a resistance load and work in this application?
In looking at the many soft starters available there is not much if anything about resistant load capabilities.
Good Answers: 34
Re: Soft Start?
09/20/2012 1:55 PM
"The OEM used mechanical contactor and they do not hold up well"
Use solid state relay instead.
Good Answers: 804
Re: Soft Start?
09/20/2012 2:19 PM
The term "Soft Start" is a motor control device, they typically don't provide info on resistive applications because it is often done differently for that application, The same type of device for resistive loads is called an "SCR Power Controller". Different manufacturers, and there are several other design considerations regarding that. Contact people in the heating control industry.
Good Answers: 15
Re: Soft Start?
09/21/2012 4:20 AM
You generally use a soft start to limit the inrush current of an inductive device such as a large motor. You have a resistive load so will not have the same issues.
Suggest you replace the contactor but instead of going for an AC1 rated device you could go for a more substantial AC3. kW rating would be the same but made for much more onerous duty cycle.
Using a soft start might help to increase to increase lamp life by limiting the current.
You will still need a contactor to bypass around the soft start after 30 secs (ish) to reduce losses.
Good Answers: 266
Re: Soft Start?
09/21/2012 8:18 AM
These Quartz Halogen lamps have a large inrush current 8 to 14 times the operational current.
Yes the increase in lamp life was a noted benefit. But not because of reduced current. Lamp life increase due to reduced stress on the element.
Some of the soft starters that I was looking at had internal bypass.
Good Answers: 102
Re: Soft Start?
09/21/2012 9:03 AM
OK I'm with the program now.
The "inrush" current you mentioned is due to the filament being cold when it is first turned on. The cold resistance is very low.
In studio lighting applications, where nkW lights are turning on and off with gay abandon, the lamps are never turned off completely. Some current is always passed through them even when not illuminated to keep them warm/hot so that the lamps don't pop prematurely and they can also be quickly modulated in intensity (eg flashed).
Studio lighting is normally controlled with a dimmer pack with DMX control. Easy to set up this way but if you don't need this sort of control you could emulate the preheat function with external resistors paralleled across the contacts of your control device (contactor).
When the contacts are open the current flows through the resistor in series with the lamp and when the contacts close you get full voltage across the lamp and they illuminate at full intensity.
Inefficient for sure. High power resistors required...yes. You could use ordinary lamps for the high powered resistors at a pinch.
Dimmer packs have all this functionality built in and also provide multi channel controlability. They also operate standalone without DMX. They use Triacs.
I think semiconductor control is what you need here.
What was the mode of failure for your contactors? Burnt coils or fried contacts?
Does this help?
Good Answers: 266
Re: Soft Start?
09/21/2012 11:59 AM
Burnt contacts is the problem. In operation these contactor may open and close 60 times an hour. This varies depending on the size of the product. Smaller sizes are easier worked may be fed into it so frequent the lamps never go off. Large sizes may have it turning off and on 10 times an hour. Not sure contactors were design to open and close that frequently.
Good Answers: 804
Re: Soft Start?
09/21/2012 5:49 PM
Good Answers: 102
Re: Soft Start?
09/21/2012 11:33 PM
Nice one!
Add that to the library.
Register to Reply 8 comments
Joshi (1); JRaef (2); ozzb (2); silverfox (1); Wal (2)
