Previous in Forum: PN For Flow Circuit   Next in Forum: CCGT Efficiency Comparison Between 2 on 1 Multi Shaft and 1 on 1 Single Shaft
11 comments
Pressure Testing a Blind Flange
09/29/2012 3:48 PM
hey can any tell me the method whereby i can pressure test a blind flange at a pressure of 1500 psi??
Re: Pressure Testing a Blind Flange
09/29/2012 4:22 PM
Bolt it to a sealed pipe or vessel having a matching flange and a tap to admit pressurized fluid.
09/29/2012 5:37 PM
thank you. do u kno of any other methods?
09/29/2012 5:58 PM
You could even bolt it to another blind flange with a tap.
09/29/2012 7:53 PM
cud i some how use a hydo test pump 2 test it with approriate coonections?? is that feasible?
09/29/2012 8:12 PM
Of course; that's the only way it is possible. However, you should not be entrusted with such a test.
09/29/2012 8:47 PM
thank you again. can u help me wid design calcuations in designing of a blind flange?
09/29/2012 9:11 PM
Your local pressure vessel design code should give the relevant formulas. There will be one for pressure against a circular plate, one for simple bolt stress, one for leverage moments, and maybe others. The totality is too much to convey in Web postings, and needs to be accompanied with experience.
Why don't you just purchase a preengineered blind flange from a reputed vendor?
Good Answers: 34
09/29/2012 4:24 PM
This link will give you some guidance:
http://en.wikipedia.org/wiki/Hydrostatic_test
09/29/2012 9:13 PM
You are obviously not qualified to perform such tests, let alone "design" a blind flange.
Go to school.
09/29/2012 9:33 PM
lol@ lyn.im learnin.im jus in experienced
Good Answers: 34
10/02/2012 9:44 AM
To gain true experience, take up an internship with a hydro testing organisation.
Register to Reply 11 comments
Joshi (2); kliff (4); lyn (1); Tornado (4)
