Previous in Forum: Formula For Current Carrying Capacity of Al/Cu Power Cable   Next in Forum: Solar PV Module System Design
Free Fall In EOT Crane
10/01/2012 1:47 PM
In EOT crane during lowering at full notch brake is released , there is no plugging action , the rotor's direction of rotation is in a way to favor the free fall, but still there is no free fall why?
Actually what I know about it's reason is something related to frequency of the main supply line, as when there is free fall the rotor rotates much greater speed than synchronous speed ...so it alters the frequency of the staror supply i.e. main supply coming from grid ....but the grid doesn't allow the frequency to be altered and hence controlling the speed of the motor. I want to know how the frequency is disturbed and how the grid prevents the motor to alter the frequency.
Good Answers: 110
Re: Free Fall In EOT Crane
10/01/2012 2:32 PM
An induction motor produces torque in proportion to "slip," the difference between line frequency and motor frequency. Torque is produced equally well in either of the two conditions: motor faster than line frequency (braking torque); motor slower than line frequency (driving torque).
Induction motors are called asynchronous, meaning the supply frequency and the rotor induced frequency are not the same when the motor is producing torque.
http://en.wikipedia.org/wiki/Induction_motor
Think big. Drive small.
Good Answers: 266
10/01/2012 2:38 PM
Most have a secondary internal device like a friction clutch to prevent free fall. It is a safety device. Has nothing to do with the electrical supply or frequency.
The only ones that will free fall are those that are installed where there is no possibility of person being under it. Which are very few areas of use.
India - Member - New Member
Good Answers: 164
10/01/2012 6:54 PM
Way back, Cutler-Hammer (now part of Eaton Corp.) had something called the Opotor system...an opposing torque system which would come into operation during lowering injecting an appropriate opposing torque to the motor to slow it down (slip-ring motor, one assumes). It could be fine-tuned for very soft lowering when used in hot-metal cranes. i am sure it has gone highly electronic by now, but some of the old products are alive still ! http://www.eaton.com/ecm/groups/public/@pub/@electrical/documents/content/ca05801001e.pdf
04/09/2014 7:32 PM
Yes, you are very near to answer. Actually rotor speed exceeds the Ns (Sync. Speed). And it will behave as induction generator and torque generated will act as brake.
Register to Reply 4 comments
anvesh (1); K_Fry (1); kvsridhar (1); ozzb (1)
