Previous in Forum: Hydraulic Control of Frontal Milling Machine LINE 3100   Next in Forum: Motor Winding With Al Magnet Wire
Busbar Conductor Spacing
10/04/2012 6:38 AM
Is there any rules or standards for the spacing of cables tapping in a busbar?
If so please suggest, if there is any formulas and its standard.
Re: Busbar Conductor Spacing
10/05/2012 12:04 AM
Refer busbar manufacturer's literature.
pnaban
Good Answers: 170
10/06/2012 11:42 AM
Can you elaborate?
10/06/2012 10:38 PM
I think OP want to know the distance between holes in a busbar from which many cables would be tapped. From a workability point of view the distance between edges of adjoining cable lugs should allow an spanner to be used to tighten/loosen the nut.
pnaban
10/06/2012 11:43 PM
Yes actually i need to know if there is any rule to follow in deciding the distance between the holes.
Register to Reply 4 comments
electricalexpert65 (1); pnaban (2); sujinvipin (1)
