Previous in Forum: Welding Question   Next in Forum: Scoop Control in Boiler Feed Pumps
9 comments
Inner and Outer Mold Line Definition in Sheet Metal Operation
10/04/2012 1:33 PM
Hi Everyone
Can someone explain what is the purpose of specifying/Defining Inner and Outer mould lines for Sheet metal bent parts.
I browsed the net. I could find the definition but the actual practical purpose/ use is not explained!!
Thanks in advance
Sengo
Pathfinder Tags: Inner/Outer Mould lines
Re: Inner and Outer Mold Line Definition in Sheet Metal Operation
10/04/2012 7:02 PM
IML defines the intersection of a plane that runs along the inner surfaces of the part. It is located inside the radius part.
OML is outside, but defines the intersection of the plane of the outer surfaces. It is in space, off the part.
10/04/2012 11:11 PM
You could use whichever surface is expected to fit to the surfaces of other parts. Alternatively, search on "K-factor bending".
10/05/2012 5:50 AM
i am agree with Lyn.IML the inside dimensions of sheet metal part and OML is the outer (like a square or U shape to be inserted in a given dimension .
love4everyone
10/05/2012 1:03 PM
Lyn ...Thanks..
But why we need to have IML/OML..is it related or gives any input for Form Block Manufacturing or Sheet metal forming??
10/05/2012 4:08 PM
As per Lyn's explanation.
IML and OML are important beacause they establish the location of your form block surfaces.
10/05/2012 5:44 PM
If the bend radius is large enough, the IML will also lie outside the curve.
10/05/2012 5:51 PM
Correct. My mistake.
10/05/2012 6:15 PM
As per Tornado's rebuttal!
10/06/2012 5:14 AM
Thank you Guys
Register to Reply 9 comments
lyn (2); Sengottuvelavan (2); sohail0110 (1); TerraMan (2); Tornado (2)
