Previous in Forum: Ferritecore Transformer   Next in Forum: Differential Relay In Generator
9 comments
Nabco Hydraulis Valve Bank 24 Volt
10/09/2012 9:08 PM
I have a valve bank with 24 volt solenoids can anyone tell me what amperage they draw
Re: Nabco Hydraulis valve bank 24 volt
10/09/2012 9:16 PM
The spec sheet will tell you. Many web sites will tell you. It's probably written on the nameplate of the valves.
What does Nabco say? Don't they have a web site?
10/09/2012 9:53 PM
nabco only give voltage , My problem is my truck is 12 volt and the hydraulics are 24 volt and I,ve been told to use a 12 to 24 volt step up converter but I need the amps
10/09/2012 10:38 PM
There doesn't seem to be much information on the internet on these. Are the solenoids marked with a current (I) or power rating (W)?
10/10/2012 5:45 AM
Would a phone call help?
10/09/2012 10:33 PM
Wild guess 2A for a 12V solenoid; 1A for a 24V solenoid. How many might be energized at the same time? If your solenoid nameplate gives a VA number, divide by voltage to get amps.
10/10/2012 12:32 AM
there is no markings on the solenoids
I hoping to use a 12 to 24 volt converter
Re: Nabco Hydraulic valve bank 24 volt
10/10/2012 12:39 AM
I don't suppose you have an ammeter, even a cheap multimeter?
[Note: edited title.]
10/10/2012 5:46 AM
Yes. Anyone with a 24 volt power source and an ammeter can do this.
Good Answers: 34
Re: Nabco Hydraulis Valve Bank 24 Volt
10/10/2012 9:28 AM
Best way is to connect 24 V, in series with an ammeter on 5 Amp. range, to the solenoid to get the current rating of the solenoid.
Register to Reply 9 comments
jack of all trades (1); Joshi (1); lyn (1); mirf90 (2); PWSlack (2); Tornado (2)
