Previous in Forum: HT Fuse Burn Out & VCB Tripping   Next in Forum: Single Phase Generator
Voltage Between Terminal to Earth When That Particular Terminals Gets Earthed
10/10/2012 4:39 PM
Dear frnds, When Supply terminals (Say DC) gets grounded(suppose positive terminal).what will be the voltgae between earth to positive terminal,and what will be between earth and negative terminal.please provide explanation. If possible explain in AC system too.
Re: voltage between terminal to earth when that particular terminals gets earthed
10/10/2012 4:58 PM
What's the voltage on the terminal?
Good Answers: 181
Re: Voltage Between Terminal to Earth When That Particular Terminals Gets Earthed
10/10/2012 6:55 PM
Is this your homework again?
10/10/2012 8:10 PM
Most likely 0V as shorting the output of a DC power supply results in the protection operating or the DC power source overloading and blowing up, or going into current limit (in which case who knows what the output voltage will drop to). The same goes for an AC system.
If the DC power supply is electrically isolated from ground then the power supply wont blow up if you short the positive to ground, however because it is isolated you also wont measure any voltage between the Dc negative and ground, so again the answer is 0V. The same goes for an AC system.
10/10/2012 11:35 PM
Near zero, depending on the resistance of the path to ground. (Called ground fault.)
If the opposite pole (DC) or another phase (AC) is also grounded, there will be a short circuit.
Register to Reply 4 comments
jack of all trades (1); lyn (1); TonyS (1); Tornado (1)
