Previous in Forum: Current in Neutral Wire   Next in Forum: Measure Building Resistance
8 comments
Difference Between Neutral and Ground
10/12/2012 1:16 AM
Difference between Neutral and Ground in brief
Re: Difference between Neutral and Ground
10/12/2012 2:19 AM
You are asking this question why?
10/13/2012 12:55 AM
am confused,so can u explain
10/16/2012 11:58 PM
Maybe I am wrong but I thought it is quite plain what the difference is. What exactly do you not understand about Neutral and Ground? Why is it you are confused?
I am not saying you could have googled it but I have the feeling if you would have shared your confusion we would have been able to help you instantly.
Anonymous Poster #2
10/12/2012 2:23 AM
Neutral is Neutral
Ground is Ground
Cant get more brief than that.
10/12/2012 3:11 AM
Neutral carries the imbalance current where single-phase loadshave been derived from a 3-phase supply.
Ground carries the fault current until such time as the circuit protective device(s) operate(s) to disconnect the fault.
Is that brief enough?
10/12/2012 5:14 AM
Even briefer: the difference is the neutral current multiplied by the earth loop impedance. It won't get any briefer than that.
Good Answers: 29
Re: Difference Between Neutral and Ground
10/12/2012 9:33 PM
Neutral is allowed to carry current under normal use. How much is determined by supply, load and wire size. Ground is a fail-safe return for fault current. Aside from a fault, ground should not carry current.
10/20/2012 1:07 AM
neutral is the return path for completing the circuit
ground is the connection to earth to protect the equipments from faults and to protect the human from electric shock
Reply Off Topic (Score 4)
Anonymous Poster (2); fidhahusain (1); IdeaSmith (2); Lo_Volt (1); PWSlack (2)
