Previous in Forum: Difference Between Compress & Pvelite   Next in Forum: Pressure Design Thickness of Con or ECC Reducers
12 comments
Boiler Feed Water Pressure Safety Valve
10/12/2012 2:37 AM
Hello
Please can someone advise me how/help to size a pressure safety valve (PSV) on a boiler feed water (BFW) system.
The system criteria are:
BFW pumps design
Design flow 45,400kg/hr @ 72.4 barg
Economisers
Design pressure 52 barg
Test pressure 78 barg
Design temp 460 deg C
Steam Drum
Design pressure 54.1 barg
Working pressure 48.3 barg
Design Temp 270 deg C
Working temp 264 deg C
Should the PSV that is installed between the economiser and the steam drum be sized to either:
a) Max flow rate and pressure of the bfw pumps
b) The increase in pressure due to the thermal expansion of the water in the line between the bfw pumps and steam drum including the economiser coils.
Re: Boiler feed water pressure safety valve
10/12/2012 3:20 AM
Is this on a line fed by positive displacement pumps or is some other type in use? Please describe the type of pump.
10/12/2012 3:29 AM
A piping diagram might also help in showing what valves might be accidentally closed.
If the valve relieves from the economiser to the steam drum, rather than to atmosphere, be aware of the lesser pressure difference when sizing the valve.
Re: Boiler Feed Water Pressure Safety Valve
10/12/2012 9:36 AM
ASME Section I contains rules about sizing and selecting safety valves based on boiler performance and heating areas.
These valves are supplied by the boiler vendor........on a new installation
Is this a used boiler that was purchased without any safety valves ?
Good Answers: 104
10/12/2012 10:22 AM
Please understand that this response is based on very limited information and big assumptions. But it appears the whole system needs a thorough review.
I assume the system BFW flow is: pump → economizer → steam drum
Normally, the econ. design pressure (DP) would be ≥ the steam drum DP. If the steam drum PSV is set at 54 barg and the economizer is protected by a PSV set at 52 barg (its DP), then under a boiler relieving event the boiler will be starved of make-up because the BFW pressure will be limited to 52 barg by the economizer PSV. This would create a potential boiler explosion hazard.
10/15/2012 9:10 AM
The working pressure of the boiler is stated as 48.3barg.
10/13/2012 3:43 AM
Thanks for the replies
Ok here's a rough flow diagram to better explain the question.
I believe the PRV (highlighted) is not required as the system is protected by the 2 PRV's on the steam drum, unless the screwdown check valve on the steam drum is closed.
10/13/2012 10:48 AM
It looks as though the PRV protects Gen1 and Gen2 in case the downstream valve is closed.
10/15/2012 4:13 AM
"A picture is worth a thousand words" - ancient proverb.
Now that the PFD is to hand, all becomes clear.
  • The PSV in the water feed line is there to protect the two economiser units from overpressure, however it would be better positioned upstream of them, so that any blockage caused by unwanted heat exchange surface fouling in these vessels' coils doesn't cause a pressure rise upstream over that which the valve is intended to protect.
  • The lifting pressure should be the lower of the two vessels' coils' maximum operating pressures.
  • The flowrate through the valve at the lifting pressure is equal to that shown on the pump's performance curve at that pressure.
Now, go size the valve!
Good Answers: 104
10/15/2012 8:37 AM
Any suggestion for the potential problem brought up in #4 ↑?
10/15/2012 9:08 AM
If the drum PSVs are set to 48barg and the PSV for the feedwater supply is set higher, then the problem described does not arise.
The boiler can be managed so that, in the event of a low water level persisting after a relieving event, a normal shutdown can be invoked. A feedwater pump trip might also invoke normal shutdown if no standby pump is available.
Good Answers: 104
10/15/2012 9:45 AM
If the operating pressure is 48.3, the drum PSV setting is probably at least 53 and maybe 54. I don't want to get into a back-and-forth. OP should get concurrence with his organization and code insurer.
10/15/2012 10:05 AM
Agreed. Discussion and review with the Engineer/Surveyor for the company responsible for burst indemnity insurance cover on the boiler is an important and very urgent step for the original poster to make. After all, if it explodes then this is the company that picks up the tab, not the anonymous CR4 reader.
<unsubscribes>
Register to Reply 12 comments
Anonymous Poster (1); bigg (3); PWSlack (5); SloopJohnB (1); Tornado (2)
