Previous in Forum: Potential Artesian Flowing from Beneath Uprooted Live Oak Stump   Next in Forum: Tower Plumb and Twist Surveys
Eductor
10/16/2012 8:03 PM
Eductors utilize a high pressure fluid pumped through an orifice to move a solution. What is the final velocity of the mixed solution {high pressure fluid and the moved solution} in the diffuser after mixing.
Re: Eductor
10/16/2012 8:51 PM
I'd suggest that you look at some eductors on the web.
Different eductors will give different results. It's more about flow than velocity.
Serfilco (Usual disclaimer) is one source. [PDF]
EDUCTORS AND SER-DUCTOR® AGITATION SYSTEMS - Serfi
There are many others. Look here:Search GlobalSpec
Re: Eductor
10/17/2012 3:17 AM
The final velocity is the combined volumetric flow of the two streams divided by the cross-sectional-area of the downstream pipeline.
Good Answers: 104
Re: Eductor
10/17/2012 9:29 AM
This has the sound of a homework problem.
Register to Reply 3 comments
bigg (1); lyn (1); PWSlack (1)
