Previous in Forum: Welding Tank by Galvanized Sheets   Next in Forum: Welding Question
8 comments
Section 1X p Nos
10/17/2012 10:10 AM
What does p no1,2,3 4.......resemble which type of materials. And how can we easily recognize
Re: section 1X p nos
10/17/2012 10:14 AM
10/17/2012 10:23 AM
In what context?
10/17/2012 10:39 AM
Golf clubs maybe?
10/17/2012 10:52 AM
Oh, I get it. Traditionaly they would have been wood.
Here ya go:
Cleek ·Driving Iron
Mid Mashie ·3-Iron
Mashie Iron ·4-Iron
Mashie ·5-Iron
Spade Mashie ·6-Iron
Mashie Niblick ·7-Iron
Pitching Niblick ·8-Iron
Niblick ·9-Iron
Jigger ·Wedge / Chipper (approach club
Good Answers: 104
Re: Section 1X p Nos
10/17/2012 12:39 PM
Maybe you're referring to ASME Section IX, 'Welding and Brazing Qualifications'? If so, p numbers refer to classifications of materials, the ones you listed are all ferrous, if I recall. I no longer have access to the published code, but if you are working in that area, you need that access, available by purchase from ASME. As far as 'easily recognize', I'm not sure what you mean.
Good Answers: 34
10/18/2012 1:34 AM
P Numbers are assigned to base metals for the purpose of reducing the number of welding and Bracing procedures qualifications required.
P Numbers are alphanumeric designation: Accordingly, each P number shall be considereda separated P Number,
See ASME IX QW-420
11/07/2012 3:24 AM
narasimha34:
P - Numbers are used to group materials to reduce the number procedure qualifications. For example, if you have qualified welding procedure for P1 material (SA 106 Gr.B) can be used for other P1 family materials as long as no change in F number (Electrode and filler wire classification) and A number (weld metal chemistry).You can find the complete list of listed materials and it's P-Numbers form ASME BPV Sec IX QW/QB 422.
08/13/2013 12:00 PM
You can only start recognizing them when you start working with them on frequent basis. Following should help you in remembering some groups you often do work with. Further detailed grouping is also available, if you want.
Base Metal Welding
Steel and steel alloys P-No. 1 through P-No.11, including P-No. 5A, 5B, and 5C
Aluminum and aluminum-base alloys P-No. 21 through P-No. 25
Copper and copper-base alloys P-No. 31 through P-No. 35
Nickel and nickel-base alloys P-No. 41 through P-No. 47
Titanium and titanium-base alloys P-No. 51 through P-No. 53
Zirconium and zirconium-base alloys P-No. 61 through P-No. 62
Register to Reply 8 comments
bigg (1); birken (1); lyn (2); PWSlack (1); sanweld (1); user-deleted-1105 (1); Whitephone (1)
