Previous in Forum: USB to serial port converter   Next in Forum: Process Integrates 3D Interconnects
Conversion from USB to serial port
05/21/2007 3:19 AM
I use a dongle (a small hardware device ) that connects to the 25 pin serial port of my laptop. The dongle authenticates the use of proprietary software.
Now I have bought a new laptop that does not have the 25 pin serial port. It has the 13 pin serial port for VGA and USB ports. I tried using a 'converter' (one end a USB and the other end a 25 pin connector) and hooked the dongle to it. It did not work.Nor did it work on a 13 pin to 25 pin converter.
Any ideas on how to make it work?
Ashok Pillai
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member Hobbies - Musician - New Member
Re: Conversion from USB to serial port
05/21/2007 9:07 AM
Hi Ash,
I ran into the same problem. I didn't use a dongle, but my PLC communication cable was serial. I ended up getting a PCMCIA card with 2 serial inputs and it works fine. I got it on the internet - I don't remember where right now. You can probably do a search and find one.
Hope this helps,
Mike
"Blessed is the man who, having nothing to say, abstains from giving us wordy evidence of the fact." George Eliot [Mary Ann Evans] (1819-1880)
Good Answers: 120
05/22/2007 3:40 AM
you may be able to use one of those USB to serial converters or ask the vendor to trade your old dongle for a USB type.
all the new ones are USB
Per Ardua Ad Astra
05/22/2007 8:07 AM
You can get the required interface for RS232 protocol at this link below:
http://www.quatech.com/
Register to Reply 3 comments
aurizon (1); coyot1 (1); mikey (1)
