Previous in Forum: Audio amplifier transient testing   Next in Forum: Conversion from USB to serial port
USB to serial port converter
05/21/2007 3:07 AM
I use a dongle (a small hardware device ) that connects to the 25 pin serial port of my laptop. The dongle authenticates the use of proprietary software.
Now I have bought a new laptop that does not have the 25 pin serial port. It has the 13 pin serial port for VGA and USB ports. I tried using a 'converter' (one end a USB and the other end a 25 pin connector) and hooked the dongle to it. It did not work.Nor did it work on a 13 pin to 25 pin converter.
Any ideas on how to make it work?
Good Answers: 97
Re: USB to serial port converter
05/21/2007 4:43 AM
It is not supposed to be easy.
The software developers would have encountered the problem already and may rather want to replace the dongle or supply a software fix. Contact them.
05/21/2007 9:00 AM
iawtc - contact the s/w vendor and get a USB key. It should be an easy thing to do.
05/21/2007 11:14 PM
Are you sure it's not a parallel port? That would take a different converter (USB to parallel...)
05/21/2007 11:22 PM
Unfortunately many laptops (and desktop PCs) and USB-serial converters don't always implement the serial protocols correctly. I have found that Dell laptops are particularly bad. I have had to use trial & error to find a USB-serial converter brand/model that does work - often it is the cheaper ones, but I don't normally get more than about 1 in 3 to operate correctly.
However, before spending the time & money, do as previously suggested - go back to the software company & ask if they have an alternate solution - many have USB dongles available now.
Popular Science - Weaponology - New Member Greece - Member - New Member
05/22/2007 2:36 AM
You can ask FTDI or PROLIFI companies that produce ICs for serial to USB converters .They maybe answer what you could do
athmio
Good Answers: 50
05/22/2007 2:43 AM
The 25 pin connector was a parallel port. The dongle connected to that. The VGA port is not a serial port, although it looks like one. If your new laptop does not have a parallel port, which many don't, you've screwed the pooch. Your only hope is to contact the software company and ask what they have to support laptops in this case.
05/22/2007 11:02 AM
I previously have found a serial to usb that comes with software that will work
like this but not the one I used
DB-9 Serial Adapter High Speed USB SERIAL RS-232
Anonymous Poster (3); athmio (1); bhankiii (1); Hendrik (1); vermin (1)
