Hi all
WE have a motor that triped with overload, I decoupled the compressor from the motor and started it up.
Within a few seconds a fuse blew, I meggered the motor winding and found all ok. Replaced the fuse and restarted it, this time 2 fuses burnt out, and I noticed that while the motor free wheeled to a stop that the direction of rotation was incorrect... I find this strange .. as the compressor has been in service for about two years.. could a faulty contactor cause a motor to loose a phase causing it to rotate in a different direction and then blow two fuses ?
