Previous in Forum: Intermetallic Particles in Brass   Next in Forum: The ceramic Internal Combustion Engine.
Rotary Feeder
05/21/2007 6:42 AM
How to design a rotary feeder for something els?
Best Regard
Re: rotary feeder
05/21/2007 7:00 AM
What are you intending to re-design it to do??
Just saying "....design a rotary feeder for something else" leaves an awful lot to the imagination.
John.
Good Answers: 54
Re: rotary feeder
05/21/2007 8:07 AM
What "else" are you referring to?
The quality (and kindness) of the responses you'll get is proportional to the quantity and quality of your question. A short question will result in either a wrong answer or a retort from the people here.
Describe what you're doing and be more detailed about your problem.
Good Answers: 101
Re: Rotary Feeder
05/22/2007 1:17 AM
What do you want to do with it? You must first specify what you intend to use it for, otherwise no one can help you.
Re: Rotary Feeder
05/22/2007 9:28 AM
Before design,you have to know what goods feed to what place.And what device fit to work with.Than calculate some factor and make draft drawings.
william.bei
Re: Rotary Feeder
05/22/2007 10:03 AM
That question is alike to "how to design a chair?"
There is a lot of thing after "design a ..."
Re: Rotary Feeder
05/22/2007 12:49 PM
My sugestion is to contact "Recycling Equipment" And ask for Josh in engineering.
"Better a diamond with a flaw, than a pebble without." Confucius
Anonymous Poster (1); DVader1000 (1); Electroman (1); shanem8888 (1); user-deleted-1114 (1); Vulcan (1)
