Previous in Forum: Finding Lost or Misplaced Items   Next in Forum: Bandwidth Requirements
17 comments
Transmitting Composite Video Via a Laser
10/28/2012 6:52 PM
Would it be possible to transmit composite video through a laser beam using a laser at the transmitting end and a photodiode or other fast sensor at the receiving end? There would obviously have to be amplifiers to bring the signals to the correct voltage. I read that someone managed to transmit an spdif audio signal with an LED and photodiode.
Lasers can be set to different brightnesses so this should work for an analogue signal also?
It would be interesting to have the laser at the shed and the photodiode receiver on the house. The audio might have to be done through another laser but that is not vital.
Pathfinder Tags: laser communication
Good Answers: 110
Re: Transmitting composite video via a laser
10/28/2012 7:45 PM
Yes, of course. Optical telephone lines transmit video (and all sorts of other information) in many locations throughout the world.
This article discusses some of the issues.
Think big. Drive small.
Good Answers: 84
Re: Transmitting Composite Video Via a Laser
10/29/2012 1:37 AM
Yes, it is possible. I built an aparatus in the early 70s to do just that, using a Pockels cell and a polarizer to amplitude-modulate the light. Detected the beam using a PIN photodiode. Won me my first airplane ride, it did! I was a junior in high school. Very fond memory.
10/29/2012 6:24 AM
Thats a shame. No pockels cells on Ebay.
I did find this though. Would this alone connected to an amplifier be suitable?
http://www.ebay.co.uk/itm/BPX65-PIN-Photodiode-/120998522205?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item1c2c12ed5d
Good Answers: 84
10/29/2012 7:48 AM
Transmitting analog composite television signals would be a piece of cake today. No need to use a Pockels cell, you can modulate a diode laser directly. My laser back then was a home-built He-Ne job using a Metrologic 0.5 mW tube. Had to immerse the damn thing in a magnetic field to keep the polarization from rotating.
10/29/2012 9:45 AM
What type of laser diode and sensor would I need? Also, what electronics am I going to need? I am needing something with the bandwidth to support video. It is about 6 Mhz of bandwidth I am needing.
Good Answers: 84
10/29/2012 9:56 AM
There's a tale of a young apprentice who demanded of his teacher the world's knowledge whilst standing on one foot...
You've got the entire Internet before you, and yet here you are, asking for what is essentially the complete design? Shall I shop for the parts also, and serve them to you on a silver platter with fresh-cut flowers and a lace tablecloth?
You do the research first, then come back if you have any questions which you simply cannot answer. You'll not learn a single thing if it is handed to you, I guarantee it. You'll learn plenty if you do do it yourself and you'll proud that you did. You've got resources at your disposal that were scarcely dreamt of thirty years ago. Use them. Relying on someone else only makes them more expert, not you.
10/29/2012 7:30 PM
Excellent answer!
10/29/2012 8:50 PM
I will just buy an IP camera and attach a yagi antenna to it.
Good Answers: 38
10/29/2012 9:19 PM
10/29/2012 10:54 PM
I haven't read this but look here it might help
Good Answers: 12
10/29/2012 11:21 PM
Today's fiber optic communications uses lasers and photodiodes to do just that. You can put whatever you want on it...video, audio, data. I can't see why you couldn't use the same principle (even identical) only operating at different wavelengths and adjust the circuit. Chose your transmitter laser and photodiode to suit. I can't see how you will get a stable communication link as it will be difficult to align and calibrate the laser to point directly to the photodiode...and consider falling leaves, dust etc breaking the line.
10/30/2012 6:18 AM
optical fibre works on same concepts (digital to then electrical signal are change in formof light again same modulation and demodulation
10/30/2012 9:01 AM
I am just struggling to find an op amp with a wide enough bandwidth to support video.
Good Answers: 12
10/30/2012 5:27 PM
Ok...Here's one that we use from Texas Instruments
Brazil - Member - Professor - UNICAMP
10/30/2012 11:46 AM
Well,the laser light may be considered a high-frequency carrier, for example, a light with lambda = 1.5 micra, has a frequency of ~200Thz. Any signal to be transmitted by that carrier (for example by modulating the amplitude of the light with one video signal) can not occupy 0.01% of range offered by the carrier. So you can transmitte your signal. LED light is another source that you can use without problems.
Edson Moschim
Good Answers: 38
10/30/2012 9:21 PM
Good Answers: 67
05/02/2014 7:09 PM
This brings back memories.
Wrote a paper in 1972 on this very subject, based on my research at the local uni. They were quite generous in letting me, a nerdy, long-haired high-school junior, use their lab facilities. Today? Probably not.
My lab gear consisted of a polarization-stabilized He-Ne laser, a Pockels cell with amplifier to modulate the polarization angle, followed by a fixed polarizer to amplitude-modulate the beam and, at the receiving end, a PIN photodiode and associated electronics. My paper won the regionals along with five other students (two from each state, three states in our region) and so we got to compete in the Nationals. It was my first airplane ride and the first time I tasted (way too much) scotch. Very fond memories!
Register to Reply 17 comments
brettj1au (1); daffy (2); Edson Moschim (1); Epke (2); europium (3); europium mkII (1); FAUZI (1); hydrogenhead (4); K_Fry (1); redfred (1)
