Previous in Forum: Calculating Shrinkage   Next in Forum: Transformer Room Ventilation
Pipe Flow Equation for Non Viscous Fluid
10/29/2012 9:27 AM
Sir,
Could you tell me the Bernouli's equation for the case of a pipe from a tank bottom connected to a tank which is below the first tank. diameter of the pipe is constant.
Considering the surfaces of a liquid level as sections 1 and 2, liquid as non viscous fluid with no losses in the pipe line (bend, contraction, expansion...), tank liquid surfaces are z1 and z2 m height from the datum, Bernauli's equation reduces to z1-z2 = 0.
But actually z1-z2 is not equal to zero.
why this contradicting result? is this because of choosing my sections 1 and 2 or any other reasons? this same will come, if i choose two cross sections in a vertical pipe of constant diameter? kindly correct my understanding.
Re: pipe flow equation for non viscous fluid
10/29/2012 9:30 AM
Re: Pipe Flow Equation for Non Viscous Fluid
10/29/2012 10:22 AM
All fluids have viscosity. So the starting point is not valid.
If the viscosity were zero, then the flow through the pipe would be infinitely large, the top tank would empty immediately into the bottom tank and the illustration would not be representative.
So start again.
Location: OHIO, tri-State design and installation, and travel nationally and consults also are international
09/10/2013 3:06 AM
Newtonian
A Newtonian fluid is a viscous fluid whose shear stresses are a linear function of the fluid strain rate. Mathematically, this can be expressed as: t
ij = Kijqp*Dpq, where tij is the shear stress component, and Dpq are fluid strain rate components.
perfect
A perfect fluid is defined as a fluid with zero viscosity (i.e. inviscid).
Simply choose your utility supplier contracting WITHOUT BROKERS and opt-out of community aggregations for free choices.
09/10/2013 3:22 AM
But a real fluid having some viscosity, also has a rotational velocity in a stream in such as a constrained domain as within piping, too. - 'some' affecting perfect results about respect to a formula
09/10/2013 3:02 AM
  • Bernoulli's EquationBernoulli's Equation The Bernoulli equation states that, where points 1 and 2 lie on a streamline, the fluid has constant density, the flow is steady, andwww.princeton.edu/~asmits/Bicycle…Bernoulli.html -
  • Bernoulli's equation - Physics Forums LibraryBernoulli's equation Library Item. Find a definition, equations, related links and scientists on Bernoulli's equation at Physics Forums. Register to discuss Bernoulli ...www.physicsforums.com/library.php…115 -
09/10/2013 3:11 AM
had some fun (off topic) watching ~ 10 ft of 2" (1.93" I.D.) PE 3408 x sdr11 pipe with ~14ft of head from a reservoir
deliver over 65 gpm of water , open end straight downward off one 90-elbow from a bulkhead
JP76 (4); lyn (1); PWSlack (1)
