Previous in Forum: Air Temp in Boiler Room   Next in Forum: Centrifugal Pumps In Series
9 comments
Rediogry Testing (RT) in Piping
11/01/2012 7:47 AM
Who will Decide RT % in piping?
Whether engineering or Quality Department.
Good Answers: 61
Re: Rediogry Testing (RT) in Piping
11/01/2012 11:05 AM
First- The Applicable Piping Code
Second- The QA/QC Department
Do it once and do it right
Re: Radiography Testing (RT) in Piping
11/01/2012 2:15 PM
Follow the most stringent of 1) applicable piping codes, 2) contract documents, and 3) internal QA/QC.
Editorial note: Radiography.
11/01/2012 11:35 PM
Thank you for your reply
But I have one more query that RT % is based on Joint efficiency. & How QA/QC dept. will define joint efficiency.
Please explain in details.
11/02/2012 4:37 AM
QA/QC is not there to define the joint efficiency. It is there to make sure there is evidence gathered that the applicable code/applicable specification has been followed.
11/02/2012 4:45 AM
Agreed sir
but My question is still open means how quality people will decide how much percentage of Radiography testing ( RT % ) to be done in piping
Please elaborate.
11/02/2012 8:26 AM
See #4↑. QA/QC isn't there to do that either.
11/02/2012 9:58 AM
In the U.S. boiler and pressure vessel code, you may claim 70% weld efficiency if no RT is conducted, 85% if spot RT, and 100% if full RT. Unless the RT is required, the decision is an economic choice.
11/02/2012 11:55 PM
Thank you for your answer.
Please explain how to calculate Joint efficiency? or on which basis joint effieciency will be calculated?
11/03/2012 12:20 AM
It isn't calculated; it is simply prescribed based on what portion of RT is done; as explained in the earlier post.
Register to Reply 9 comments
PennPiper (1); PWSlack (2); sachin salunkhe (3); Tornado (3)
