Previous in Forum: Leading Power Factor   Next in Forum: Please Help in Determining the Secondary Terminal of CT
8 comments
Wooden Furniture in Electrical Substations
11/03/2012 8:49 AM
I have commmonly heard that wooden furnitures and cartons are not allowed inside substation ,are there any international standards which mention the same.Please advise if so.
Pathfinder Tags: substations
Re: wooden furnitures in Electrical substations
11/03/2012 10:10 AM
It would probably fall within fire codes. Different classes of fires require different methods of extinguishing. Having a combined alpha and charlie fire, just makes things more complicated.
http://en.wikipedia.org/wiki/Fire_classes
I think this would go beyond wood though. I believe that most local codes would not allow the use of substations as storage lockers.
I don't know where you are, but in the US, we probably have 15 different government agencies telling us not to pile up junk in substations.
http://www.osha.gov/pls/oshaweb/owadisp.show_document?p_table=standards&p_id=9868
Good Answers: 125
11/03/2012 11:02 AM
Don't forget Bravo. Transformers in substations are oil filled, and are the greatest fire hazard there.
11/03/2012 11:53 AM
Yeah. That oil would burn, but it would take a pretty good explosion to rupture the transformer walls. At that point, I'd just let her burn. I guess the new silicone based oils are almost nonflammable.
Nonetheless, with or without written rules, piling up wooden crates, boxes and furniture inside a substation is not a good idea. I'd invest in a separate shed.
Good Answers: 125
11/04/2012 11:31 PM
Sometimes they just leak, and then burn.
Agreed on the piling up of wood though.
Good Answers: 170
Re: Wooden Furniture in Electrical Substations
11/04/2012 8:51 AM
Assuming that you are from India, refer to IE Rule No. 29.
01/23/2024 3:07 AM
It is certainly ill-advised to have <...Wooden Furniture in Electrical Substations...>.
  • Why wait for <...international standards...> to surface?
  • Why not just take the initiative, and do the right thing by getting rid of it instead? As in right now?
01/23/2024 7:52 AM
It is not forbidden in our country and we had a good practice to have documentation at paper form in every substation and transmission plant. For a short time while we had an American employer 15 year ago , our fire fighter service had an internal recommendation that all flammable material should be removed from high voltage facilities. Unfortunately, management took it literally and we lost all documentation . So now our younger workers have a problem with incomplete and incorrect documentation in repairs and emergency situations .
01/23/2024 10:13 AM
Metals burn as well, though...
Register to Reply 8 comments
electricalexpert65 (1); kramarat (2); Panta SD (1); PWSlack (2); WJMFIRE (2)
