Previous in Forum: How to Choose Instrument Cables for My Cables   Next in Forum: Stanchion
9 comments
Thread Entry
11/06/2012 7:43 AM
Hi All,
Any advise, we have one control vlv IP positioner entry thread damege during the cable glanding, need your advise any way to repair the entry thread to avoid replacement of the positioner.
REgard
Re: Thread Entry
11/06/2012 9:04 AM
If not irreparably damaged, you can often 'chase' threads by running a correct tap through the hole.
If irreparably damaged, is there enough room for something like a Helicoil or Permacoil?
Good Answers: 34
Re: Thread Entry
11/06/2012 9:10 AM
We can not see, what you see. You therefore, are the best judge. Could you not post a picture?
Anonymous Poster #2
Re: Thread Entry
11/06/2012 10:22 AM
Could you not post a picture?But he's already 'not posted' a picture...
Maybe if he did post a picture that would help.
Mr I. M. A Literal Pedant
Re: Thread Entry
11/06/2012 9:14 AM
Can it be tapped-out to the next gland size up (obviously not if it is an EEx d installation in a hazardous area)?
Re: Thread Entry
11/06/2012 11:30 AM
Silly question, but are any codes involved? Like NEC or BS?
Re: Thread Entry
11/06/2012 11:45 AM
I am supposing that if any applicable codes were in play our original anonymous poster would certainly have advised us.
Well, maybe not.
Re: Thread Entry
11/06/2012 12:29 PM
Codes? CODES?? We don't need no stinking codes! (Paraphrase from Treasure of the Sierra Madre.)
Re: Thread Entry
11/06/2012 2:23 PM
What material is the damaged thread made of (some are plastic while others are metal)?
Is it being installed in a hazardous area (in which case entry modification options are seriously limited)?
If this is for an industrial application only then drilling the hole out to the next size up and using a reducer gland may also be an option.
Re: Thread Entry
03/29/2013 12:19 AM
Hi All
Instrumentation junction box entry hole, th design for the single pair cable entry was on the front and the spare hole was on the back, any concern if all cable glanded on the front hole and spare hole on the back.
Any advise
Regard
Abdulla
Anonymous Poster (2); Doorman (2); jack of all trades (1); Joshi (1); lyn (2); PWSlack (1)
