Previous in Forum: Establish Acceptance Level - How?   Next in Forum: Superfluous Affix Agglutination Creep
8 comments
Interpretation of UCS 5(b)
11/07/2012 12:24 AM
Hi,
ASME Sec VIII-Div1 UCS 5 (b) states that " Carbon or low alloy steel having a carbon content of more than 0.35% by heat analysis shall not be used in welded construction or be shaped by oxygen cutting (except as provided elsewhere in this Division)."
1. Is it mean that oxygen cutting shall not be used on any carbon steel or alloy steel used for pressure vessel construction based on SEC VIII-Div1?
OR
2. Is it mean that oxygen cutting shall not be used, when any carbon steel or alloy steel contains more than 0.35% carbon content?
Could anyone help me to understand the clause clearly?
Thanks
Re: Interpretation of UCS 5(b)
11/07/2012 12:43 AM
Neither. Please read the original statement more closely.
11/07/2012 1:17 AM
OK,What is your interpretation?
11/07/2012 1:22 AM
There may be allowable exceptions "as provided elsewhere in this Division".
11/07/2012 1:31 AM
That means,
1.As long as no allowable exceptions are not available in this division (Sec VIII-Div1), oxygen cutting of carbon and alloy steel having carbon content more than .35% are not allowed?
OR
2.As long as no allowable exceptions are not available in this division(Sec VIII-Div1) , Oxygen cutting of carbon and alloy steel are not allowed irrespective of carbon content?
11/07/2012 1:51 AM
1. No.
2. No.
Your expressions have not accounted properly for double negatives (no...not), and thus are not correct understandings. Moreover, they are more complicated than the clause(s) you are trying to understand.
11/07/2012 2:36 AM
Yes you are right. Thank you for pointing out the problem. I have used one extra 'No' in the sentences, which had altered the entire meaning!So,I reword it.
As long as allowable exceptions are not available in this division (Sec VIII-Div1), oxygen cutting of carbon and alloy steel having carbon content more than .35% are not allowed and carbon steel/alloy steel below 0.35% carbon percentage can be cut by oxygen. Is it correct interpretation?
11/07/2012 4:01 AM
Yes, though it doesn't explain why.
11/09/2012 2:20 AM
Thanks.Getting the right interpretation of code is valid.Remaining story is available in metallurgy books.
Register to Reply 8 comments
PWSlack (1); sanweld (4); Tornado (3)
