Previous in Forum: Cutting Safe Distance From Weldments   Next in Forum: Different Thickness Required
MAWP Limited by Nozzle Reinforcement
11/08/2012 2:42 AM
I designed a pressure Vessel in PVElite and I got this waarning in my report that my MAWP is limited by the Nozzle Reinforcement Pad. I have tried to increase the pad thickness, vessel thickness and nthey all seem to have no effect.
Plz I need suggestions on wat to do.
Thanks alot.
Need ur answers really fast.
Thanks all once again
Pathfinder Tags: MAWP nozzle reinforcement PVELITE
Re: MAWP limited by Nozzle Reinforcement
11/08/2012 2:48 AM
This isn't the first time we have heard of odd results when using PVElite. If they have a help line, that should be the best place to ask. (Well, it should be, but it may not actually be.)
11/08/2012 8:21 AM
You must be working under a deadline. I just love deadlines. I especially like the whooshing sound they make as they fly by.
Do your own homework.
Re: MAWP Limited by Nozzle Reinforcement
11/09/2012 9:23 AM
You do not have to do anything unless a Specification (customer or local) requires that "THE MAWP SHALL NOT BE LIMITED BY A NOZZLE" as ASME code Section VIII, Division 1 does not. It sounds like the additional thickness you are adding to the re-pad is outside the limit. Otherwise, did you try to maximize the re-pad OD ? How about using Long Weld Necks (expensive) ? How about inserting a thicker shell section at the nozzle ?
Good Answers: 11
11/09/2012 9:51 AM
Are you familiar with ASME Section VIII? It's good practice to read that before designing a vessel to it. I'm guessing that you've used the maximum reinforcing area and are still limited by that nozzle. I can direct you to which section but I think it would be best to read most (if not all) of the UG section in there.
Register to Reply 4 comments
cingold (1); lyn (1); Mechanicalmark (1); Tornado (1)
