Previous in Forum: Geotermal   Next in Forum: MAWP Limited by Nozzle Reinforcement
15 comments
Cutting Safe Distance From Weldments
11/08/2012 12:21 AM
Dear Gurus,
Hi! we are in a project of disassembling of a large steel tank which shall include cutting using plasma.
Can anybody help to provide a safe distance from the weldments/joints to do the cutting without jeopardizing the metallurgical properties of the metal?
Is there any standard/s that this can be made as reference?
Your help would be of great help.
Thanks.
Re: Cutting Safe Distance From Weldments
11/08/2012 1:04 AM
This is only rule of thumb, but IIRC a safe distance is the greater of 2 inches (50 mm) versus 2.5 time the width of the existing weld. If you search on "heat affected zone" (HAZ) of welds, you may find better information.
11/08/2012 1:25 AM
Thank you Tornado..does it mean, no internationally acceptable standard/s stating this rule?
11/08/2012 1:38 AM
I don't know, but I doubt that there is a universal standard.
11/08/2012 2:01 AM
OK, thanks much for the info.
11/09/2012 10:18 AM
Please check page 29 of this material, which might give answer to your question.
www.http://www.iacs.org.uk/document/public/publications/guidelines_and_recommendations/pdf/REC_47_pdf193.pdf
11/08/2012 3:27 AM
Why are the metallurgical properties of great interest in a vessel cutting operation?
11/08/2012 4:47 AM
we intend to rebuild/reweld the vessel.
11/08/2012 4:50 AM
So, why plasma-cut it in the first place? Why not cold-saw or use a grinding/cutting disc?
Does this tank have a pressure rating? If so, then scrapping it and starting with virgin metal would be a far better bet.
What fluid is going inside the tank, its temperature and pressure?
11/08/2012 5:06 AM
cold saw, grinding/cutting disc is not possible.
other clarifications not relevant already.
thanks.
11/09/2012 9:18 AM
Time/cost.
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
11/08/2012 9:41 PM
You can refer to this link:
http://www.weldguru.com/welding-safety.html
11/09/2012 12:39 AM
Dear Sir,
My comments to the following inquiry. I was involved in a similar restructuring & repair work to a large petroluem tank 2 years ago in most probably similar to the situation you are in now.
My solution to cutting the 15mm steel plate was by using a very high water jet cutting machine. If I can remember the pressure rating was somewhere between 800 to 1000 bars and I managed to hire the unit from a Ship builder I knew. All I needed was a siphon pump to discharge the water out during the cutting procedure. The main 100hp electrical motor driving the piston pup was placed outside and I need a 5000 gallon tank of water on a trailer for the main feed.
Some bracket modification work was required inside the tank to hold the water jet nozzle in position with one operator inside during the cutting process. Communications by walkie talkie for a 2nd man at the opening overseeing the cutting operations to the main pump operator.
NO HEAT - No Metal Fatique. Clen cut is all I needed.
Hope this helps.
11/09/2012 9:13 AM
Great answer especially for a first timer! Welcome to CR4!
11/19/2012 12:58 AM
Water jet cutting is actually top on the list, but we're finding a way to minimise cost and plasma comes next.
Thanks very much:)
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
11/09/2012 8:15 AM
Cover the area you want protected with weld blankets and/or use a heat sink to direct heat away from the area you want protected. You can find them at any weld shop or hardware store.
UFG
Dirt is for vegetables. Pavement is for racing.
Register to Reply 15 comments
Darolim (1); jmmyadam (1); john kingham (1); lito (5); Mechanicalmark (1); PWSlack (2); ronclarke (1); Tornado (2); unclefastguy (1)
